AC help - Mustang Evolution
Old 07-04-2012, 07:13 PM   #1
Brandonb2012's Avatar
AC help
one thing after another lol well about a week ago my ac started blowin hot and i went down road n it started smoking i turned car off n popped hood n the belt was burning where it goes around the compressor....i went to walmart n charged it up n it took a while but it went back to.normal...but today it did it again...i went to a friend and he said he thinks i need a new compressor....and my clutch like moves without AC on...i thought it only.turned wit the AC? idk suggestions?
Brandonb2012 is offline   Reply With Quote
Old 07-04-2012, 08:02 PM   #2
1slosix's Avatar
Re: AC help
may have burned out the compressor if you ran it too low on oil..you can try adding a bottle of oil in and seeing if that helps..you can buy it at any autoparts...i forget if our cars run pag 100 or 150 but you can run 100 as a safe guess...or just ask anyone there to pull it up for you on their computers.
although the smoking has me worried...i've seen a few compressors light up lol because people have run them without oil. and remember refrigerent does not take the place of oil in an A/C system
Old 07-04-2012, 08:11 PM   #3
Yes i knew.they took oil n.figured it needed somethin like.that so i.bought the can.with oil lol but im.sure thats not enough if it was out...im still confused...it makes ticking noises n my clutch looks like its rattling...i may get a couple of opinions from.mechanics around here n see what they say....how.would.i add only oil?
Old 07-04-2012, 08:15 PM   #4
1slosix's Avatar
Re: AC help
i'd say the compressor is shot...but you can add just oil by buying a can of just oil...it's next to the A/C refridgerent
Old 07-04-2012, 11:37 PM   #5
it goes in same way?
Old 07-05-2012, 01:36 AM   #6
1slosix's Avatar
Re: AC help
Yes you can get puncture cans of oil
Old 07-05-2012, 04:30 AM   #7
so what u recommend? my acs been blowin fine all night but i can just hear the compressor makin alot of noise
Old 07-05-2012, 12:32 PM   #8
Fourloko530's Avatar
My ac blows air but warm tried adding freeze stuff but the thing on the can said it didnt need it
Fourloko530 is offline   Reply With Quote
Old 07-05-2012, 02:21 PM   #9
see if your clutch spins when u have the ac on
Old 07-05-2012, 04:48 PM   #10
Re: AC help
***The R-134a can of refrigerant has a gauge on it. Put the gauge back on, turn on AC MAX, rev engine almost to 2K RPM and look at the gauge. If low, add some more refrigerant. 35-40 Lbs (Reading on gauge) is full. You probably have a major leak.
Old 07-05-2012, 05:58 PM   #11
but it says its for like a 80-85 degree temp outside...its like 95-100
Old 07-05-2012, 07:22 PM   #12
okay my belt popped hahaha im just gunna replace everything what all do i need? compressor...bout how many cans of freon? and oil?
Old 07-07-2012, 01:27 AM   #13
Re: AC help
You need to recover what refrigerant is left. Test it for acidity. System needs pulled into a vacuum, 5-10 microns, checked for leaks before adding the refrigerant.
10:04 PM
