battery issues - Mustang Evolution
Old 07-05-2012, 04:47 PM   #1
Horseplay's Avatar
battery issues
went to the store a while ago and car didnt wana start it just died. opened the hood and messed around with the battery and it started right up. i noticed the negative connection isnt tied down hard enough cuz its got a crack. how do i replace this ? need some help plez
Low2v
Old 07-05-2012, 04:56 PM   #2
Re: battery issues
You go to a quality auto parts store and ask for a negative battery terminal. To remove old one- Loosen that rusty nut, use screwdriver to widen gap, pull old cracked terminal upwards. ALWAYS be careful not to ground out positive (Red) cable, it can explode, harm you, burn you, ect,.. Next, cut off old terminal with side cutters or similar tool. Use razor blade knife to trim back an inch of insulation, exposing shinny new copper to place the new one on. Install the new one following directions on package. *Before you cut off the broken terminal, make sure you have enough cable length to reach the battery with new terminal, your cable will obviously be shorter after cutting off old one.
Old 07-05-2012, 05:06 PM   #3
Havoc's Avatar
Lol
Hav·oc/ˈhavək/
Noun: Widespread destruction.
Verb: Lay waste to; devastate.
2000- V6 First Stang
Havoc is offline   Reply With Quote
Old 07-05-2012, 05:11 PM   #4
Horseplay's Avatar
thanks robb. so i just cut off the old terminal then ?
Low2v
Old 07-05-2012, 05:19 PM   #5
Re: battery issues
Yeah, if it's crimped on.
11:30 AM
