Windstar Install Time? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 07-10-2012, 05:43 PM   #1
willrad00's Avatar
willrad00 is unknown around these parts
So after usps denied my adress existed... twice, then lost the package on the return, its finally here!!! So i was wondering how long install should take? Can i get it done after work one day or will it take a whole day?
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline
Old 07-10-2012, 05:53 PM   #2
Horseplay's Avatar
Horseplay is unknown around these parts
did u get the full kit
Low2v
Horseplay is online now
Old 07-10-2012, 06:04 PM   #3
willrad00's Avatar
Re: Windstar Install Time?
yup, one of the last full kits he sold!
Old 07-10-2012, 06:15 PM   #4
Horseplay's Avatar
damn LUCKY u !!!
Low2v
Old 07-10-2012, 06:20 PM   #5
willrad00's Avatar
Haha i ordered it like a month ago, i finally told stven to screw usps and just payed extra for ups.
Old 07-10-2012, 07:10 PM   #6
kickerofdoom's Avatar
kickerofdoom is unknown around these parts
A day I think
kickerofdoom is offline
Old 07-10-2012, 09:23 PM   #7
willrad00's Avatar
ok,and does the diagram with all the vac lines come in the box or do i hav to email him?
Old 07-10-2012, 10:41 PM   #8
davidcseifert's Avatar
davidcseifert is unknown around these parts
the vacuum lines are really simple to figure up on it, the brake booster goes to the 3/8 barb at back, the pcv valve hose coming from drivers side valve cover (should you choose to keep it) goes to the barb in the front on drivers side that sticks through the coil bracket, the fuel line vacuum hose runs from the tiny 1/4" fitting coming from passenger side corner (it's a factory hose to which it connects coming from that corner) then T's off to a tiny barb back by where the brake booster hooks up and continues to the front of the fuel rail on drivers side and attaches to it with a hose clamp (recommend you get new hose clamps as the ones in VAP's kit stripped during my install), the vacuum line running from the top of the intake goes to the 3/8" hose that also comes from the passenger side corner), and the final vacumm line goes from the passenger side valve cover to the smaller barb on the black intake pipe
any questions feel free to ask, i've done the install a couple times over haha
as to time frame, i had complications with parts during install and took about 4-5 hours somewhere around there
SSM S3 heads, P&P lower, comp 218/226 cam, 4.2 bottom end, 3k stall, flow 40's, O/R x-pipe, Pacesetter lt's, SCT xcal2 (93 Ortizperformance tune), Windstar upper, 65mm tb, CAI, FRPP T-lok, 3.73's, SFC's, cut factory springs, KYB shocks/struts, MM LCA's
Sponsored by Ortiz Performance, great tunes at a good price!
davidcseifert is offline
Old 07-11-2012, 08:44 PM   #9
willrad00's Avatar
Haha thanks David, If i lose my instructions can i just hit you up and not bother printing more out?
Old 07-11-2012, 09:47 PM   #10
if you want to sure, it's not a bother to me
Old 07-12-2012, 02:37 PM   #11
willrad00's Avatar
haha i was just kidding, but if i run into trouble i'lll shoot u a pm, thanks david!
Old 07-12-2012, 02:41 PM   #12
sixpac's Avatar
sixpac is unknown around these parts
I was looking for a windstar intake for my 01 and I have seen 3 diffrent upper intakes that say there for an 01 windstar confused??
Horse Power sells cars, Torque Wins Races.
2001 Mustang GT 4.6..
sixpac is offline
Old 07-12-2012, 02:46 PM   #13
sixpac's Avatar
Should it look like this?
And I need the lower as well right?
sixpac is offline
Old 07-12-2012, 08:13 PM   #14
Kingmidas87's Avatar
Kingmidas87 is unknown around these parts
Yeah I was lookin up intakes too and had the same problem but that definitely not the right intake. Check Partstrain.com
Kingmidas87 is offline
Old 07-12-2012, 09:10 PM   #15
Just_John's Avatar
Just_John is unknown around these parts
I installed mine, from start to finish in my driveway in about 9 hours.
THE ONLY REASON that it took that long was because I allowed my 19 year old son to "help" me. If I had been alone I could have gotten it completely installed in less than 6 hours.
Granted, I have been wrenching on cars for 30 years, so I do have a fair understanding of how things should go together...
The "high temp silicone hose" that Steven includes in the kit lasted less than 3 weeks. It got hard and brittle and flaked apart. I replaced it with plumbing fittings and tubing from the hardware store, and sealed it with fireplace sealant. Now, a year later, my repair is STILL solid as a rock and doesn't leak. I wish I had done an EGR delete and eliminated the need for that hose in the first place.
Good luck with your installation and believe me when I tell you............. "You will not regret this purchase"!
Edit: When I ordered my Windstar kit from VAP I got it overnight.... HAHAHA that is only because I live about 100 miles away from him !
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline
Old 07-12-2012, 10:31 PM   #16
Attachment 58723
thats it, and yes you need lower intake, it has a special design
Old 07-13-2012, 06:41 AM   #17
willrad00's Avatar
to delete the egr do i just cap both sides with a compression fitting? or can i plug it somehow?
Old 07-13-2012, 02:51 PM   #18
Havoc's Avatar
Havoc is unknown around these parts
I'm going to be a buzz kill what does the lower intake manifold look like?
Hav·oc/ˈhavək/
Noun: Widespread destruction.
Verb: Lay waste to; devastate.
2000- V6 First Stang
Havoc is offline
Old 07-17-2012, 10:08 PM   #19
it's easier to just make a little plate that removes the egr valve all together
like this
1999-2003 Ford Windstar Intake Manifold - 1380013 Replacement - Lower Air Intake 99-03 Windstar Intake Manifold - PartsGeek.com
Closed Thread
10:00 PM
