Code 2270 - Mustang Evolution
Old 07-13-2012, 10:51 AM   #1
Dgerow12's Avatar
Code 2270
^i believe this is the code I got. I have a 2004 v6 5 spd bone stock. Code said o2 sensor stuck lean. And possibilitys were exhaust leak, misfire or fuel injection system badly out of calibration. I had an exhaust leak on my 00 and it doesn't sound like I have one on this car. And I don't think it's a misfire because the car runs great but does feel like it idles a little rough. Anyone have any ideas on what this could be or anyone have this code before??
Dgerow12 is offline   Reply With Quote
Old 07-13-2012, 09:47 PM   #2
1slosix's Avatar
Re: Code 2270
that code is for bank 1 sensor 2. what exhaust do you have on there? that code is normal to pop up for people when they swap midpipes on GTs (i know i did lol)...i ended up just using MIL eliminators to kill it, but lets delve further in your issue because it may not be the sensors reading causing the light
Old 07-14-2012, 12:17 AM   #3
Dgerow12's Avatar
It's a bone stock v6 with the stock single exhaust
Old 07-14-2012, 10:43 AM   #4
1slosix's Avatar
Re: Code 2270
could actually be a faulty downstream sensor then
Old 07-14-2012, 12:35 PM   #5
Dgerow12's Avatar
The code goes away after a while tho. It only seems to happen when I take off as soon as I start it
Old 07-15-2012, 09:18 PM   #6
1slosix's Avatar
Re: Code 2270
swap the two downstream sensors...after a full drive cycle see if the code stays the same or shifts
11:16 AM
