07-17-2012, 12:30 AM
#1 | | Registered User
| NEED HELP! 04 Mustang 3.8l Oxygen sensors?
Hi everyone, so let me first start this off by saying, I really don't know much about cars. I do know the basics and can figure stuff out quickly, I just don't have to full knowledge of it as you guys do.
Anyway, I have a 2004 Mustang V6 3.8l and about a week ago my "check engine light" came on. So the other day I took it to get the codes read and this code came up: P2195
Its says it has to do with the oxygen sensors. Here's what the print out says the probable causes are:
1. Failed HO2S11 (Bank 1 Sensor 1)
2. Open or short circuit condition
3. Failed fuel pump or blocked fuel filter
4. MAF sensor failure
5. Vacuum leak
I replaced both of the sensors in front of the converter, took it back to AutoZone to make sure its still just throwing that 1 code (it was) and then had him clear the codes. Then I took it back home and by about mile 6 I figured "Hey since I drove it a little already, I should probably go ahead and shut her down and start her again to see that does anything." Did that, drove about 200 feet then the light came back on.
So basically, what the f*ck do I do? lol Since its some emissions crap, do you think I might have to drive it for a full drive cycle for it kick in or something and the light will just go away? What do you guys think it could be? Any help what be very appreciated!
Oh btw! Would the failure of the oxygen sensors have an effect on my gas mileage? I feel like I'm getting crappier mpg
07-17-2012, 12:00 PM
#2 | | Registered User
My o2's are out too doesn't do to much I don't feel like. If it affected ur mpg's it's prolly insignificant. Auto zone should be able to check exactly what it is. Maybe take it back and try again. I check mine and it specifically says my o2's have failed. Maybe you have a few things goin on? I believe my back ones are the ones failed btw. If you have a tuner you can turn your sensors off so no more check engine light
"Hp sells cars, Tq wins races" - Carroll Shelby
Black and yellow, black and yellow!
Runnin' circles around one camaro at a time |
07-17-2012, 12:07 PM
#3 | | Registered User
Well I have a code of lean bank 2 and i know that It's the oxygen sensor. If you have code for the oxygen sensor it self that means the thing is still working you have a different problem. Oxygen sensor should be change every 100k miles I have 164k and have stock so i need to change both my mpg are decent so they don't cause much change in my mpg
07-17-2012, 09:47 PM
#4 | | Staff
| Re: NEED HELP! 04 Mustang 3.8l Oxygen sensors?
even if he cleared the code it only killed the light...it didn't reset the live memory. you may have fixed the issue and it's running fine now but the light won't go out 100% until you complete a drive cycle. If the light is still on after 100 miles then have it retested. If you'd like to reset your live data before doing a drive cycle pull the negative battery terminal off for 15 minutes...hook it back up and then we'll see how it goes in a cycle  hope this helps
07-17-2012, 10:01 PM
#5 | | Registered User
Yea I really shouldn't even have to replace the O2 sensors because it only has 67k on it... but sh*t happens.
Thanks for everyones feedback and here's a pic of the Autozone code receipt.  ---------- Post added at 09:00 PM ---------- Previous post was at 08:59 PM ---------- Holy cow thats a big pic! lol Well, easier to read eh?!  ---------- Post added at 09:01 PM ---------- Previous post was at 09:00 PM ---------- Quote:
Originally Posted by 1slosix even if he cleared the code it only killed the light...it didn't reset the live memory. you may have fixed the issue and it's running fine now but the light won't go out 100% until you complete a drive cycle. If the light is still on after 100 miles then have it retested. If you'd like to reset your live data before doing a drive cycle pull the negative battery terminal off for 15 minutes...hook it back up and then we'll see how it goes in a cycle  hope this helps | Thanks, I'll def give it a shot! Appreciate the help |
07-17-2012, 10:04 PM
#6 | | Staff
no problem...and you'd be surprised how many customers i get with bad o2 sensors. mileage really doesn't play into it....the quality of gas does more then anything. that and if the fuel isn't burning right it can foul out the sensor if you're running too rich
07-17-2012, 10:11 PM
#7 | | Registered User
| Re: NEED HELP! 04 Mustang 3.8l Oxygen sensors? Quote:
Originally Posted by 1slosix no problem...and you'd be surprised how many customers i get with bad o2 sensors. mileage really doesn't play into it....the quality of gas does more then anything. that and if the fuel isn't burning right it can foul out the sensor if you're running too rich | Good to know! May have to feed my baby the good stuff
So a full drive cycle is 100 miles on a mustang? I've already driven about 60 on it since the lights been reset. Should I just go ahead and pull off the negative side off the battery and wait 15min? Will I still have to drive the full cycle after I take disconnect the battery, or should it just be good?
07-17-2012, 10:14 PM
#8 | | Staff
Originally Posted by berry21 Good to know! May have to feed my baby the good stuff
So a full drive cycle is 100 miles on a mustang? I've already driven about 60 on it since the lights been reset. Should I just go ahead and pull off the negative side off the battery and wait 15min? Will I still have to drive the full cycle after I take disconnect the battery, or should it just be good? | honestly i don't know what the drive cycle is...somewhere between 50-100 miles on most vehicles. and after pulling the battery you'll need to do the drive cycle if you're gonna go through emissions. if not they'll fail you just on the not passing on the drive cycle part (been there lol and only because i needed a new battery a day before emissions) if you still have a light on after it though get it retested and see if the code is the same or shifted...if it's the same and the o2's were replaced i'd start looking for leaks
07-17-2012, 10:25 PM
#9 | | Registered User
Originally Posted by 1slosix honestly i don't know what the drive cycle is...somewhere between 50-100 miles on most vehicles. and after pulling the battery you'll need to do the drive cycle if you're gonna go through emissions. if not they'll fail you just on the not passing on the drive cycle part (been there lol and only because i needed a new battery a day before emissions) if you still have a light on after it though get it retested and see if the code is the same or shifted...if it's the same and the o2's were replaced i'd start looking for leaks | Thanks! I really appreciate all the help. I just disconnected the battery, so I guess I'll find out soon |
07-17-2012, 10:27 PM
#10 | | Staff
Originally Posted by berry21 Thanks! I really appreciate all the help. I just disconnected the battery, so I guess I'll find out soon  | no problem man...i just hope it helps you out
07-17-2012, 10:31 PM
#11 | | Registered User
Originally Posted by 1slosix no problem man...i just hope it helps you out | ME TOO! lol I'll keep you guys posted on what happens...
07-18-2012, 01:27 AM
#12 | | Registered User
So glad there's not emissions around here, they're a b*tch lol
07-18-2012, 08:36 AM
#13 | | Registered User
I'm sure that code isn't real
07-18-2012, 09:26 AM
#14 | | Registered User
Whats a cheap brand of O2 sensors you guys recomend?
1999 3.8 stang
1990 LX - supercharged 351w
1985 turbo 2.3 www.msvorinich.itgo.com
07-18-2012, 09:51 AM
#15 | | Registered User
| Quote: |
Originally Posted by Mike SVOR Whats a cheap brand of O2 sensors you guys recomend? | Just go to oreillys and tell them you want the chrapest
Horse Power sells cars, Torque Wins Races.
2001 Mustang GT 4.6..
07-18-2012, 10:23 AM
#16 | | Registered User
Be carefull about code readers. Autozone and Advance want to sell you stuff. Often times when an oxygen sensor code appears it is due to other things, not really that the sensor is bad it is just doing its job. If you are also throwing a MAF code that has the ability to trigger a O2 code. The car can run lean or rich and it cause a O2 code, just be carefull. I would take it to somebody that not only read but understand the codes.
__________________ Your enemy is doing what you can not. When you meet he WILL defeat you. |
07-18-2012, 11:00 AM
#17 | | Registered User
Originally Posted by kickerofdoom I'm sure that code isn't real | Why do you say that the code isn't real?
07-18-2012, 11:01 AM
#18 | | Registered User
The oxygen sensor are like 50 each so 4 of them about 200 for a set of them. ---------- Post added at 11:01 AM ---------- Previous post was at 11:00 AM ---------- Quote: |
Why do you say that the code isn't real? | Well the Ford codes say for the most part p0456 the zero is part of the number and i looked it up in a code book I can't find it. The guy put the info wrong into the scanner wrong
07-18-2012, 11:03 AM
#19 | | Registered User
So I've disconnected the battery for 20 min and then reconnected it and took it for a drive. Drove 11 miles, turned it off, turned it back on, drove 0.2 miles and then the light kicked back in. I was watching the light extra carefully. lol
Sooo, I think I might just have to take it to a Ford dealer... |
07-18-2012, 11:37 AM
#20 | | Registered User
Do a full tune up
07-18-2012, 03:05 PM
#21 | | Staff
Originally Posted by Randl114 Be carefull about code readers. Autozone and Advance want to sell you stuff. Often times when an oxygen sensor code appears it is due to other things, not really that the sensor is bad it is just doing its job. If you are also throwing a MAF code that has the ability to trigger a O2 code. The car can run lean or rich and it cause a O2 code, just be carefull. I would take it to somebody that not only read but understand the codes. | i can tell you that im a manager for an Advance and when it comes to code readings i don't make a comission if you buy stuff or not. i'm getting the same pay if you need a part or not. some weeks we sell more then others and guess what. I still get the same hours and pay week after week. Now at Orielys they have comission on certain products so this may be the case there  ---------- Post added at 04:05 PM ---------- Previous post was at 04:04 PM ---------- Quote:
Originally Posted by berry21 So I've disconnected the battery for 20 min and then reconnected it and took it for a drive. Drove 11 miles, turned it off, turned it back on, drove 0.2 miles and then the light kicked back in. I was watching the light extra carefully. lol
Sooo, I think I might just have to take it to a Ford dealer...  | you have to do a full drive cycle...it'll kick in and out during that time. even with the o2 non fouler trick it'll do the same thing until the cycle is complete. don't spend dealer cash until you finish it ok
07-18-2012, 04:47 PM
#22 | | Registered User
Originally Posted by 1slosix i can tell you that im a manager for an Advance and when it comes to code readings i don't make a comission if you buy stuff or not. i'm getting the same pay if you need a part or not. some weeks we sell more then others and guess what. I still get the same hours and pay week after week. Now at Orielys they have comission on certain products so this may be the case there  ---------- Post added at 04:05 PM ---------- Previous post was at 04:04 PM ----------
you have to do a full drive cycle...it'll kick in and out during that time. even with the o2 non fouler trick it'll do the same thing until the cycle is complete. don't spend dealer cash until you finish it ok | Ok thanks. But will the light just go off after the full cycle or will I have to have it clear again?
07-18-2012, 05:02 PM
#23 | | Staff
If the problem is fixed then itll just stay off...if its still on have it retested and see if the code is the same
07-19-2012, 01:37 PM
#24 | | Registered User
Sooo, I kinda feel like an idiot... lol
I ended up taking it to Aamco and they took a look at it. It was the O2 sensors, I just happened to replace the wrong ones when I did the work. The one that needed replacing was SUPER hard to see and find without a lift, which is probably why I missed it. Good thing I took it in, or else I wouldn't have been able to do the work in such a tight space with just a pair of ramps... $92 well spent to have my baby running good again |
07-19-2012, 03:32 PM
#25 | | Staff
Lol well mistakes happen...good thing you got it fixed. Im surprised you didnt trip more codes since you swapped the monitors with o2 sensors. So do you own a set of ramps?
07-19-2012, 11:38 PM
#26 | | Registered User
Originally Posted by 1slosix Lol well mistakes happen...good thing you got it fixed. Im surprised you didnt trip more codes since you swapped the monitors with o2 sensors. So do you own a set of ramps? | Yea, tell me about it... lol I do have my now set of ramps. Why?
07-19-2012, 11:42 PM
#27 | | Staff
Originally Posted by berry21 Yea, tell me about it... lol I do have my now set of ramps. Why? | just makes lifting a car easier for fixing things like that lol...although you want to talk tight fit...try changing out the mid pipe on a GT lol. the install is hell on your knuckles
