high RPM's? - Mustang Evolution
Old 07-18-2012, 04:11 PM   #1
Bamman's Avatar
high RPM's?
Is it normal for my car to ideal at 1500 RPM's when I first start it?
8 Cylinders Little Brother.
Bamman is offline   Reply With Quote
Old 07-18-2012, 04:14 PM   #2
1slosix's Avatar
Re: high RPM's?
yes but after a few moments it should drop to around 700 rpm
Old 07-18-2012, 04:15 PM   #3
Bamman's Avatar
Mines at about 1k.
Old 07-18-2012, 04:18 PM   #4
1slosix's Avatar
Re: high RPM's?
then that's idling a bit high...clean the MAF and IAC and see how it sits after that. probably a bit dirty lol. i just cleaned mine last month and even after just 50k miles on the motor they needed it
Old 07-18-2012, 06:44 PM   #5
Fourloko530's Avatar
How u clean ur maf ans what is iac
Fourloko530 is offline   Reply With Quote
Old 07-18-2012, 06:45 PM   #6
There's a cleaner for maf sensors. Iac is idle air control
Blackedout is offline   Reply With Quote
Old 07-18-2012, 06:46 PM   #7
Where the idle control at
Old 07-18-2012, 06:58 PM   #8
redstang98's Avatar
Whats a IAC unit . Motor dumb here
redstang98 is offline   Reply With Quote
Old 07-18-2012, 07:15 PM   #9
Little ways up close to the throttle body
Old 07-18-2012, 07:21 PM   #10
redstang98's Avatar
I have a 98 . Do u have a pic.
Old 07-18-2012, 07:36 PM   #11
Google images
Old 07-18-2012, 08:23 PM   #12
1slosix's Avatar
Re: high RPM's?
yep...just two bolts and unplug the sensor...you can spray it out to clean it with the same spray cleaner for MAF sensors.
Old 07-18-2012, 08:43 PM   #13
redstang98's Avatar
And what is that
Old 07-18-2012, 08:52 PM   #14
Kingmidas87's Avatar
I had to make a custom gasket for my IAC valve to get it to idle right. Before it would idle around 1000 and the rpms wouldn't drop when the clutch was engaged. After the gasket it idles around 600 and drops instantly between sifts making it easier to slam gears.
Kingmidas87 is offline   Reply With Quote
Old 07-18-2012, 09:23 PM   #15
1slosix's Avatar
Re: high RPM's?
Originally Posted by redstang98 View Post
And what is that
it's literally called Mass Air Flow sensor cleaner...it's in a spray can usually near the carb cleaner
Old 08-16-2012, 09:25 AM   #16
truckdriver0's Avatar
Would that sensor issuse cause crappy fuel mileage? Trying to figure out whats the deal with my low fuel miles? I have a post somewhere...lol new to this mustang forum
truckdriver0 is offline   Reply With Quote
Old 08-17-2012, 12:29 AM   #17
davidcseifert's Avatar
Region: Arkansas
Re: high RPM's?
a dirty MAF could hurt your mileage some yes..
blower/new cam soon
Old 08-20-2012, 03:38 PM   #18
Hey my 2001 v6 feels like its always on go, from when i let go of the brakes, rpms are normal. Just wondering if thats a problem, never owned a mustang b4, or is that normal?
Old 08-20-2012, 04:59 PM   #19
Region: Arkansas
Re: high RPM's?
as in the rpms stay higher while you're just sitting there? what does it idle at in gear and in park?
blower/new cam soon
Old 08-20-2012, 05:56 PM   #20
Re: high RPM's?
You can disconnect the negative side of the battery too,,after cleaning it,,this will reset the baro reading in the maf..Alot of times they can get stuck at one baro reading ..If its a low reading you can get pinging problems,,to high can cause rich condition problems..
mymustang is offline   Reply With Quote
Old 08-20-2012, 09:52 PM   #21
I idle at 500-700 mostly around 600. Sitting. 2100 at 70 mph.
Old 08-21-2012, 11:52 PM   #22
Region: Arkansas
Re: high RPM's?
that sounds pretty normal bud, maybe even a touch low on idle
blower/new cam soon
07:02 PM
