replace just one tire or both? - Mustang Evolution
Closed Thread
Old 07-19-2012, 05:30 PM   #1
Send a message via Skype™ to iphonemaster93
my passenger side front tire popped yesterday and I didn't find out until today when I took it onto the road (thank god I realized it before I got too far away from my house). my question is, should I just get a replacement for that one tire or should I switch out both the left and right side? which is cheaper?
iphonemaster93 is offline
Old 07-19-2012, 05:38 PM   #2
slow281
sixpac's Avatar
Region: Nebraska
Well it's cheaper to buy one obviously..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline
Old 07-19-2012, 05:41 PM   #3
It's not me, it's you.
primer2tone's Avatar
It's cheaper just to replace the one. But you've gotta check the other one out. If you've got less then 4/32 tread depth you might as well replace it also because the new tire will have over 7/32 and you don't want there to be a big difference in tread hight. Your car could start pulling to one side if the tread heights are substantially different. 2/32 is the minimum depth for state inspection btw.
primer2tone is offline
Old 07-19-2012, 05:45 PM   #4
Re: replace just one tire or both?
so if i were to bring it into a shop (most likely a gas station), should i just tell them to check the tread on both tires and see if it's necessary to replace both?
Old 07-19-2012, 05:48 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
Well yeah but they might want you to just buy two.. More $ in there pocket..
---------- Post added at 05:48 PM ---------- Previous post was at 05:47 PM ----------
Bassicly look at your others tire.. If its okay.. Then don't replace it..
2001 GT - True Blue
sixpac is offline
Old 07-19-2012, 05:50 PM   #6
Nah, dude. Check it yourself. If you ask them, of course they're going to tell you to replace both of them.
Here, this'll help.
http://www.tirerack.com/tires/tirete....jsp?techid=51
Old 07-19-2012, 11:27 PM   #7
1slosix's Avatar
either use a penny to check your tread or buy a tread tool for a couple bucks at any autoparts...
i'm a believer of replacing two at a time btw, unless one side has at least half tread (usually if i have the other tire below half tread, but above 4/32nds i'll put it in the garage as an emergency replacement)
1slosix is offline
Closed Thread
02:37 AM
