sea foam + vacuum line - Mustang Evolution
Old 07-20-2012, 02:05 PM   #1
joey18's Avatar
Going to put some sea foam in my car for the first time, can someone post a pic of whats the best vacuum line to use?
joey18 is offline   Reply With Quote
Old 07-20-2012, 02:34 PM   #2
Re: sea foam + vacuum line
The easiest one to use is the pcv valve while running. Put a drinking straw in can and hold straw up to pcv valve to suck in slowly. The oil vapors that contaminate travel through the pcv valve so it's not a bad place to introduce it. Otherwise use the vacuum canister line.
Old 07-20-2012, 02:53 PM   #3
joey18's Avatar
Okay i know this might ne a dumb question but can you post a pic or explain exactly where that is?
Old 07-20-2012, 03:24 PM   #4
shaqfu's Avatar
Let me google that for you
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 07-20-2012, 03:37 PM   #5
joey18's Avatar
Never mind found it! Never done this to my car before so there was so much smoke! Freaked out all my neighbors! Haha
Old 07-21-2012, 08:57 PM   #6
Good deal. You'll notice smoother idle, acceleration, MPG, ect.. I do the Seafoam cleaning in the gas tank and one can for upper intake right before I drain the oil for oil change. For the hell of it, I replace the fuel filter every oil change too. My oil changes are 6,000 miles+ though, using Mobil1 Extended Service 5w-30.
Old 07-21-2012, 09:13 PM   #7
joey18's Avatar
Yeah the idles kinda rough right now but ive read that you needa put some miles on it then its smooth. That true for you? And i only put it in the upper intake and gas tank because i just changed my oil not to long ago but im going to add it next oil change forsure
Old 07-21-2012, 11:28 PM   #8
I slowly sucked it up in there till it smoked no more. Did it slow, for about 45 minutes. A little bit at a time. I have never, ever put it in my oil. The only time I would do that for someone else, is if I were to find sludge inside. And rather than putting Seafoam in the oil, I would first try using Pennzoil Ultra and a high quality oil filter like Amsoil, Royal Purple, or K&N. I use Mobil1 ES myself, but I know that the Pennzoil Ultra cleans out engines very, very well. Especially dirty, sludgy ones.
04:25 AM
