best shift points for each gear? - Mustang Evolution
Old 07-20-2012, 06:10 PM   #1
Send a message via Skype™ to iphonemaster93
with 3.73s, when should I shift for each gear for max power? not running any custom tunes, i tend to shift between 5K and 5300 RPMs but then torque comes it as low as 2200 RPMs so idk when the right timing to shift would be...i use mountain roads a lot too so i tend to need more power when going uphill.
iphonemaster93 is offline   Reply With Quote
Old 07-20-2012, 11:17 PM   #2
kickerofdoom's Avatar
Do you have a tuner or get your computer tuned to 3.73 gears
Old 07-20-2012, 11:29 PM   #3
Re: best shift points for each gear?
without having the car make any weird sounds while accelerating, no or else I would have tuned it at least a month ago. I have the SF3 tuner, installed 91 custom tune once, but then returned it back to stock because it was making a strange noise (i can't describe it) so i put it back to stock.
Old 07-20-2012, 11:32 PM   #4
Well you need the tune or at least the car to be set for the gears. The noise I'm not sure maybe they didnt install it right or the tune has the timing off. The thing is your rpm and stuff will be off. You should be at ideal about 100 rpm higher if I remember right. Trust me you will feel more power when everything works out
Old 07-20-2012, 11:39 PM   #5
so what should I do then? take it into an auto shop and have them tune it for me or contact BAMA?
Old 07-20-2012, 11:40 PM   #6
Contact bama ask them about the tune. They should be able to help you.
Old 07-20-2012, 11:43 PM   #7
I actually called them the day it happened and they said it could be anywhere from spark plug wires to something else, I don't even remember. they told me to fix stuff up first and then to install the custom tune but problem is, i don't have the extra money for it
Old 07-20-2012, 11:48 PM   #8
Well what I would say is to pull each spark plug and check to see if any of them are having problem. In my car my one spark plug wire sometimes comes off the spark plug and causes problem so just check to see everything is ok
Old 07-20-2012, 11:50 PM   #9
i took it into the auto shop i usually take it to and the guy said they need to be replaced yes, but i have another like 9 months with them until they completely just blow
Old 07-20-2012, 11:53 PM   #10
You don't wanna go that far. Spark plugs are cheap I did a full tune up for like 40 dollars. Just don't push your car 5000 or higher on the rpm and i think you won't damage anything just try to be soft till then
Old 07-21-2012, 12:02 AM   #11
does a full tune up only swap out the spark plugs or is there more to it?
Old 07-21-2012, 12:07 AM   #12
Air filter,oil change,spark plug,tire air,fuel filter. Just make sure everything is running change what needs to be change stuff like that. If you wait till something breaks can cause other problems or even death. Like for me my ball joint fell off on the street if i was going on the highway and that happen very dangerous. I wasn't sure what the noise I heard was. Try to be proactive and change when needed and recommend.
Old 07-21-2012, 12:11 AM   #13
would auto shops have aftermarket air filters? cuz i have K&N CAI installed right now..
Old 07-21-2012, 12:11 AM   #14
slow281
sixpac's Avatar
Region: Nebraska
K&n is aftermarket and they are the best filter hands down
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-21-2012, 12:12 AM   #15
Well depending on how many miles you have if dirty you can clean them and put new oil on them. Kn recharge kit. Don't buy a new one unless it is damaged but they do sell new ones
Old 07-21-2012, 12:16 AM   #16
i have probably at max 500 miles on the filter right now, haven't even hit 1000 miles yet
---------- Post added at 06:16 AM ---------- Previous post was at 06:16 AM ----------
lol yep i went from AM to K&N. big money for such a CAI but totally worth it
Old 07-21-2012, 12:18 AM   #17
Nice i went cheap
Old 07-21-2012, 12:24 AM   #18
but if i were to go for a full tune up would i be able to go somewhat hard on the car immediately or would i still have to break into the spark plugs? cuz i plan on going into the shop on monday and going into the mountains the day after
Old 07-21-2012, 12:30 AM   #19
Spark plugs don't need break in. But like I said make a plan and think about what the problem could be don't just start throwing parts or it will cost you.
Old 07-21-2012, 12:34 AM   #20
problem is i have no idea where the sound was coming from, and no one else that i know knows how to drive a stick so i can't hear it from the outside either
01:46 AM
