turning on A/C effects clutch? - Mustang Evolution
Old 07-20-2012, 10:44 PM   #1
Send a message via Skype™ to iphonemaster93
so I realized something strange. with windows opened, I have no need for the A/C but due to the aerodynamics, opening windows while driving kills the fuel economy. problem is, whenever I DO turn on the A/C while driving, the clutch feels softer than usual and it just doesn't feel right. does anyone have any ideas on why this happens?
iphonemaster93 is offline   Reply With Quote
Old 07-20-2012, 11:33 PM   #2
aegischief's Avatar
It's actually been proven several times that driving with your windows down and a/c off doesn't effect fuel economy compared to windows up and a/c off. Driving with the a/c on can lower fuel economy by as much as 10 miles per gallon depending on the car.
---------- Post added at 12:33 AM ---------- Previous post was at 12:32 AM ----------
I have nothing on your clutch question other than it just feels softer due to the motor having more parasitic drag with the a/c on.
aegischief is offline   Reply With Quote
Old 07-20-2012, 11:36 PM   #3
kickerofdoom's Avatar
Well the ac and windows do effect gas mpg. Remember the ac uses power to make it work. So the engine works harder. Windows open effects with drag at higher speeds maybe not much but everything adds up
Old 07-20-2012, 11:41 PM   #4
Re: turning on A/C effects clutch?
the best way that i can describe it is that the clutch pedal feels as if it's vibrating as i am depressing it while switching gears when the A/C is turned on as when I have the A/C switched off, it doesn't feel like it's vibrating at all
Old 07-20-2012, 11:43 PM   #5
Well I'm not sure about the clutch but i would think maybe the cable is touching something from the ac. But I would just check around the ac and see if anything jumps at you
08:14 AM
