S C on the way! - Mustang Evolution
Old 02-27-2008, 11:25 PM   #1
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
S C on the way!
I just won this SC:
supercharger
Is there anything I will need to get? I know MAF injectors and tune. but anything else? thanks yall
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 02-28-2008, 01:50 AM   #2
afinley11's Avatar
Re: S C on the way!
Originally Posted by sledgehammer View Post
I just won this SC:
supercharger
Well make sure you have the right mounting hardware and that all your bolts are grade eight! You might also want to look into getting a Focus fuel pump (justin @ VMP). You should make pretty decnt power with the Vortech..Good luck man!
If I can be of any help email me lordchamberlan@yahoo.com
04 stang (Gone):
Best 1/4: 13.813 @ 104.35 <top MPH 109+..Durn Traction)
310/318 @the wheels Procharged 3.8L
New Baby:
1989 5.0 5spd Great plans for this monster!
afinley11 is offline   Reply With Quote
Old 02-28-2008, 05:52 AM   #3
Herbstang's Avatar
Re: S C on the way!
Sweet
Old 02-28-2008, 06:50 AM   #4
Re: S C on the way!
after its installed get a good dyno tune
Old 02-28-2008, 08:22 AM   #5
wiarumas's Avatar
Re: S C on the way!
nice
Old 02-28-2008, 09:50 PM   #6
Re: S C on the way!
will i need a tuner to start with? then the dyno justs fine tunes it? id like to get the fancly tuner from vmp that displays everything.
Old 03-01-2008, 10:34 PM   #7
Re: S C on the way!
So today I got a FPR 0-120psi, 255lph fuel pump (70gph), 19# design 3 injectors and matching 19# MAF (70mm).
Old 03-01-2008, 10:36 PM   #8
Re: S C on the way!
Now about tuning... if I install my SC how will I get it to a dyno shop? can i drive it there? aslo, will I need a hand held tuner to start wtih?
Old 03-01-2008, 10:37 PM   #9
Re: S C on the way!
one more thing, will I need a BOV? am going to run about 5psi till i get my new top end from SSM (then ill push 10-11psi).
Old 03-30-2008, 08:34 AM   #10
Re: S C on the way!
If you go to 11 psi, you may wish you had bought bigger injectors
Andy is offline   Reply With Quote
Old 04-07-2008, 02:08 AM   #11
afinley11's Avatar
Re: S C on the way!
Very true, I would say 39lb should do the job just fine!
So you live in new bedford? Do you cruise the "ave" down in Fall River...The reason I ask is I used to live up there!
04 stang (Gone):
New Baby:
Old 04-07-2008, 09:43 AM   #12
Re: S C on the way!
I never got into the whole cruising thing, and I'm just too old now My engine started leaning out with 39 lb injectors at about 340 rwhp, so keeping things around 300 rwhp is safe with them
Old 04-08-2008, 01:11 AM   #13
afinley11's Avatar
Re: S C on the way!
After that you are right, you must step it way up! On my next set up I will be running 150lbs, I know it is little over the top....but I would rather be safe than sorry!
04 stang (Gone):
New Baby:
05:38 AM
