Grinding feeling in power steering? - Mustang Evolution
Old 07-23-2012, 06:37 PM   #1
Jetsnix's Avatar
My steering has felt pretty much normal, but when i was driving today, i took a turn in a parking lot, and the steering wheel started to vibrate alittle. i started hearing a grinding sound. I brought it home immediatly, and im thinkin its power steering fluid. Any ideas?
04 V6 Coupe Divorced flow 40's, AM CAI, Dual Rockford Punch 10 in. Subs, Matrix 1500 Watt Amp, Infinity speakers
Jetsnix is offline   Reply With Quote
Old 07-23-2012, 06:41 PM   #2
slow281
sixpac's Avatar
Region: Nebraska
Do you have fluid? Any leaks?
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-23-2012, 08:49 PM   #3
Jetsnix's Avatar
Re: Grinding feeling in power steering?
No leaks at all
Old 07-23-2012, 08:59 PM   #4
johnofarch14's Avatar
Send a message via Skype™ to johnofarch14
Try to check your fluid, if it's ok. Check front suspensions tie rod end first. Warped rotors and bad pads can cause vibrations in steering wheel too.
johnofarch14 is offline   Reply With Quote
Old 07-23-2012, 09:06 PM   #5
Jetsnix's Avatar
The only time it vibrated and makes the sound is when i turn, shouldve mentioned that.
Old 07-23-2012, 09:11 PM   #6
What kind of sound? If it's only making a sound then it's your balljoint.. If it vibrates and grinding that's your brake pads or rotor. Have you noticed where the sound coming from?
Old 07-23-2012, 09:19 PM   #7
Jetsnix's Avatar
the sound is coming from the front of the car, and the best way i can explain it is a type of grinding when my car is turning, it starts when i turn the wheel, keeps happening when its still turned, and doesnt stop till i put it straight. It sounds like metal grinding together, its not loud, but it is noticeable.
Old 07-23-2012, 09:30 PM   #8
Ohhhh! Power steering. Just flush the oil and refill it. You cannot do that alone, you need a friend to turn your steering wheel while refilling.
Old 07-23-2012, 10:00 PM   #9
I would get one of those medium size hand pumps from any auto store (Don't Buy The Cheap ONE) and use it to suck out the fluid. Fill the power steering sump with Mobil1 Automatic Transmission Fluid. Siphon out the fluid every day until its a perfect match color wise as whats in the quart, bright red. It may not cure it if a mechanical part has failed but it keeps them running smooth and I still got my original in there.
*Also, check all of the bolts on and around the pump, brackets & tighten them up snug.
Old 07-23-2012, 10:05 PM   #10
Jetsnix's Avatar
so just regular power steering fluid then?
Old 07-25-2012, 08:35 AM   #11
____----_____------_____-------_______-----
Old 07-25-2012, 08:52 AM   #12
Blogger
99ford's Avatar
^ that or Mercron V.
08:26 PM
