need feedbacks due to inconsistent answers..C spring cutting - Mustang Evolution
Old 11-09-2003, 09:41 PM   #1
tire's Avatar
Send a message via AIM to tire
How much cut for 1.5" front and 1.25" rear for ford C springs?
-austin
tire is offline   Reply With Quote
Old 11-09-2003, 11:21 PM   #2
Zim
You want to **** me?
Zim's Avatar
im pretty sure its 1 coil, corey has C springs so Im sure he'll chime in here.
I like toys
Old 11-09-2003, 11:40 PM   #3
tire's Avatar
ok, i found a real site, looks like it's 1.5/.75.
looks like i need a spacer and to cut the rear dead coil.
Old 11-10-2003, 04:43 AM   #4
Danger Dude's Avatar
OK I am here . I have almost 1.5 all the way around with the dead coil cut of the rear but I have a 98. Paul (Greenflash00) experienced about 1.25 all the way around with his 2000. The weird thing I started out with a 1.25 but is took awhile to settle.
Old 11-10-2003, 12:12 PM   #5
tire's Avatar
do you cut the deal coil from the very tip of it, and go 360 deg to right above it to cut? or do you cut it 360 deg and upward from the point where the dead coil's end turns thick from the flat part?
Old 11-10-2003, 12:30 PM   #6
Looking at the back spring at the top, put the end of the spring in your hand and look at the coil directly below it you cut it even with the end. you want to have a perfect ring in your hand you have cutn off when you are thru.
Old 11-10-2003, 12:50 PM   #7
tire's Avatar
i didn't understand those instructions, but ar eyou saying just cut it for it's exactly one loop? respond asap please, i'm in 30 min parking
Old 11-10-2003, 11:09 PM   #8
Monkey's Avatar
yes, one complete loop. just make sure to not cut the small part that sits on the lower control arm sping perch
Old 11-11-2003, 09:18 AM   #9
tire's Avatar
dur.
Old 11-15-2003, 01:01 PM   #10
I cut a half loop on my 01 adn left the frotn alone, simply left the top front isolators out, made sure both rear isolators sayed in.
I cut half a ring, loop, on the rear coils and i now have 1.25 front and .8~ rear drop i am goign to either cut the other half of the dead coil or cut just a half of the half (3/4 total gone of the dead coil) i just dotn watn to go to low in the rear, i only want 1.25
Old 03-07-2004, 11:38 PM   #11
OR_Red98's Avatar
Region: Oregon
Please to let me clear a little of the fog on this here subject. According to the sheet I received with my "C's" You can cut 1/2 a coil off the bottom of the front springs and off the top of the rear springs. This should give you and added .5 to .75 inches of drop, which if you add that to initial drop .75 should give you a 1.5 inch drop.
Well let me tell yuh either Ford is fibb'n or maybe I was just too aggressive in breaking in my springs but I ended up with a 1.75 drop. I had to put some Ethane isolators from ES to get .25 inches back, now it's purrfect.
Dennis........Retired USAF, Disabled Vet.
http://www.mustangmods.com/data/666/the_stang_005.jpg
Red "98" coupe V6 AT. Saleen boby kit, 18" replica Saleen rims, FMC "C" springs, Mach 1/Tokico shocks/struts, GT sway bars, GT STB, Sequential turn signals, Euro head lights and clear corners, BBK CAI and GT take-off exhaust.
OR_Red98 is offline   Reply With Quote
Old 03-08-2004, 01:51 PM   #12
if you do not cut the front or rear you get 1.1 up front and .5 rear. If you cut a half coil on the front you will probably be around 1.7 no doubt, I took out my front top isolator and got 1.3 front and I have only cut half the rear coils for .8, they need more to even the drop all around.
Old 03-08-2004, 01:57 PM   #13
I am not sure why the 99+ dont drop as much as the 94-98 but I got just at a 1.5 drop
Manual Transmissions due to be endangered?? SVTCOBRA General Car Discussion 14 07-07-2009 03:58 AM
New member looking for answers!!! Won it!!! 2005-2010 Mustang GT 28 04-19-2009 07:26 AM
Yahoo Answers wiarumas The Bar 2 08-02-2007 02:28 PM
11:03 PM
