Help! - Mustang Evolution
Old 07-25-2012, 02:49 PM   #1
Dogbitdude's Avatar
Help!
I was driving today and every few stops I would make my car would almost refuse to move from the line. I would have to gas in and it wouldn't move at all and when it did it would feel like trying to start a car from the line in 5th gear, extremely sluggish. I have an auto tranny. Has anyone else experienced this? And if so what is it fixed by?
Dogbitdude is offline   Reply With Quote
Old 07-25-2012, 03:00 PM   #2
joey18's Avatar
Have you looked to see if theres any major vacuum leaks?
joey18 is offline   Reply With Quote
Old 07-25-2012, 03:16 PM   #3
Dogbitdude's Avatar
How do I check for those?
Old 07-25-2012, 03:24 PM   #4
joey18's Avatar
-Turn the engine on
-open the hood
-listen for any air coming out from any where (like a hissing noise)
-if you do hear any thing locate it and you'd need to replace that hose
I had some power loss before and it was that one of my vacuum lines was leaking, i replaced it and it was better.
---------- Post added at 04:24 PM ---------- Previous post was at 04:22 PM ----------
If its not that then could be the tranny
Old 07-25-2012, 03:25 PM   #5
Dogbitdude's Avatar
Ok thanks. I've been having a popping noise recently that gets faster as the rpms rise. Think that might be a vacuum problem?
Old 07-25-2012, 03:29 PM   #6
ForsakenProto's Avatar
Im having the same problem as well, but mine is due to badly clogged injectors. Try running some seafoam in the gas tank, and if that doesnt work, some shops offer a service for about $100 that will completely clean out your injection system, as well as remove any build up from your valves and cylinders. Of course this is after youve checked for vacuum leaks
ForsakenProto is offline   Reply With Quote
Old 07-25-2012, 03:44 PM   #7
joey18's Avatar
Id say do the sea foam no matter what i sea foamed my car last week for the first time, that stuff is awesome!
Old 07-25-2012, 03:58 PM   #8
Dogbitdude's Avatar
I did the seafoam in the gas tank a few weeks ago so I don't think it would benefit by doing that
Old 07-25-2012, 03:59 PM   #9
joey18's Avatar
Did you do it in the vacuum line?
Old 07-25-2012, 04:01 PM   #10
Dogbitdude's Avatar
No just in the gas tank. Which line is it for the vacuum line?
Old 07-25-2012, 04:35 PM   #11
Mike SVOR's Avatar
Re: Help!
brake caliper(s) locked up?
Is the car hard to push in neutral?
Jack it up and try to turn the wheels.
and for the love of all that is sane... no more sea foam 'quick-fix' solutions.
1999 3.8 stang
1990 LX - supercharged 351w
1985 turbo 2.3 www.msvorinich.itgo.com
Mike SVOR is offline   Reply With Quote
Old 07-25-2012, 04:39 PM   #12
joey18's Avatar
I put it in the pcv valve
---------- Post added at 05:39 PM ---------- Previous post was at 05:38 PM ----------
I didnt sea foam my car to fix anything nothing was wrong i simply did it for a cleaning
Old 07-25-2012, 06:32 PM   #13
Dogbitdude's Avatar
This is what my car is doing at idle
Old 07-25-2012, 07:00 PM   #14
Horseplay's Avatar
when was the last time u changed the plugs, wires , and coil pack
Low2v
Old 07-25-2012, 08:04 PM   #15
Dogbitdude's Avatar
I got them all changed when I got the car last September
Old 07-25-2012, 08:35 PM   #16
1slosix's Avatar
Re: Help!
my GT did this...it was an upstream o2 sensor...since it was faulty it was messing the air/fuel mixture up big time.
Old 07-25-2012, 08:38 PM   #17
Dogbitdude's Avatar
The thing is I don't have any codes :/
Old 07-25-2012, 08:39 PM   #18
1slosix's Avatar
Re: Help!
have it tested anyways to be safe
Old 07-25-2012, 08:42 PM   #19
Dogbitdude's Avatar
Ok. I just don't want my car randomly dying on me. I gotta get to work lol
Old 07-25-2012, 08:42 PM   #20
Lorraine's driver
ab_mach1's Avatar
I've had that on an auto tranny in a Chevy 1500 truck before. The tranny electronics were forcing it to 3rd because there was a fault going on. So in any forward gear, it was always in 3rd no matter what speed. I know that was a Chevy, but the reason I mention it is that it did not make the check engine like come on. The only way I found this out was at a tranny shop.
Also, sometimes low tranny fluid can cause them to do weird things. Hope that helps somehow.
Instagram: @ab_mach1
Old 07-25-2012, 08:48 PM   #21
Dogbitdude's Avatar
Ya it does because it feels like my car does that sort of thing. I will be moving forward and I'll be in third or sometimes even fourth only. Even if I am moving from a complete stop
---------- Post added at 10:48 PM ---------- Previous post was at 10:47 PM ----------
And my tranny fluid is alright. I checked that today. Good color and level
Old 07-25-2012, 09:01 PM   #22
Lorraine's driver
ab_mach1's Avatar
Can you look and make sure there aren't any damaged plugs or wiring coming from your tranny? Maybe a plug that is covered in oil or something that could cause a short?
Old 07-25-2012, 09:05 PM   #23
Dogbitdude's Avatar
I'll check tomorrow morning. Truthfully I want it to be a tranny problem so I have an excuse to do a swap
Old 07-26-2012, 09:49 AM   #24
Mike SVOR's Avatar
Re: Help!
Sounds like header gasket leak.
1999 3.8 stang
Old 07-26-2012, 12:38 PM   #25
Dogbitdude's Avatar
How can I fix that?
Old 07-26-2012, 01:24 PM   #26
Saucywalnuts's Avatar
Could be a clogged cat
Saucywalnuts is offline   Reply With Quote
Old 07-26-2012, 09:08 PM   #27
1slosix's Avatar
Re: Help!
How can I fix that?
just unbolt the manifold and swap the gasket...rebolt and tq down the manifold..
06:13 PM
