exhaust leak - Mustang Evolution
Old 07-27-2012, 11:29 AM   #1
exhaust leak
Does anyone else have a ticking sound in their exhaust? I've seen another mustang with it, and I wondered if it was a common problem.
Supersnake04 is offline   Reply With Quote
Old 07-27-2012, 11:31 AM   #2
slow281
sixpac's Avatar
Region: Nebraska
It's a very common problem.. Look at your manifolds for cracks and black..
---------- Post added at 12:31 PM ---------- Previous post was at 12:30 PM ----------
I'm kinda pissed because when I bought the car the dealership said its normal and then it seals up.. Wtf did I no.. He said nothing was cracked..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-27-2012, 12:25 PM   #3
Spencerb102's Avatar
I had the same problem. You can use a stethoscope to locate the location of the crack but I'd bet it's on the exhaust manifold like the other guy said. It's usually the passenger side. If the ticking goes away eventually then it is an exhaust leak. When the exhaust pipe get hot it expands and the crack is sealed (thus making the ticking stop) you can replace the manifold or the manifold gasket. Oorrrr you could have a lifter Tick. Those arnt too rare either
Spencerb102 is offline   Reply With Quote
Old 07-27-2012, 12:30 PM   #4
My manifold was cracked when I bought it, welded it back together, but now I sound like a timer going down the road.
Old 07-27-2012, 12:36 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
It might be leaking again
---------- Post added at 01:36 PM ---------- Previous post was at 01:36 PM ----------
If it was a lifter it would be a very fast tick
2001 GT - True Blue
Old 07-27-2012, 09:07 PM   #6
Re: exhaust leak
Don't mean to ask a stupid question but, When at idle, does the tapping go away when you put slight pressure down on clutch petal?
Old 07-28-2012, 11:42 PM   #7
I have an auto Tranny
Old 07-28-2012, 11:53 PM   #8
davidcseifert's Avatar
Region: Arkansas
Re: exhaust leak
just find the leak and have it welded up, unless it's just a gasket, in that case you know the drill...
blower/new cam soon
exhaust
10:21 PM
