V6 CCRM / PFDM ISSUE SES w/ p1233 code - Mustang Evolution
Old 07-29-2012, 02:51 PM   #1
I drove throught the major rain storm on Tuesday and my ses light came on and the car stalled out on 40 and my cell phone battery was dead... It really sucked. Anyway, to make a very long story short the car now still has ses coming on after clearing it twice. I can start it and maybe drive 3 miles or so before it stalls / misfires / hesitations, ses light on, right turn signal light stays on ( no blinking ) , head lights stay on but very dimm. Also, the right turn signal light stays on ( no blinking ) , head lights stay on but very dimm and a ticking sound coming from passenger engine bay - all when the car is off with keys out of ignition. After hours of reading forums it appears that the CCRM OR FPDM has gone bad. I checked the inertia cutoff switch and it is working properly. Has anyone ever had any issues like this? Any help would be great. Anyone know where to get the parts on a budget ?
Thanks.
Kenk is offline   Reply With Quote
Old 07-29-2012, 04:17 PM   #2
kickerofdoom's Avatar
Junkyard will be your friend. But maybe water got sucked into your engine
Old 07-29-2012, 04:40 PM   #3
1slosix's Avatar
Re: V6 CCRM / PFDM ISSUE SES w/ p1233 code
Its a fuel pump code....so can you hear it prime everytime?
Old 07-29-2012, 06:27 PM   #4
I know it's a fuel pump code however I'm having other issues so I believe it the ccrm that control other relays. I also notice that the second I turn on the a/c I get the ses light, car then hesitates, right turn signal on, headlight on.
---------- Post added at 04:27 PM ---------- Previous post was at 04:25 PM ----------
Anyone know any thing about this ccrm:
Cardone Remanufactured 73-70012 - Body Control Computer | O'Reilly Auto Parts
Old 05-29-2013, 12:50 PM   #5
Region: Arkansas
what did u do to fix this? please help Im having the same problem as I type and I need to find out what it is.. Pleeeeease reply back
JCulclager is offline   Reply With Quote
Old 05-29-2013, 06:32 PM   #6
Xaperez100's Avatar
The ccrm controls a lot of things.. If its bad your A/C won't turn on either. Try hitting it a few times maybe it'll fix but what the guy above was saying about water in the engine... That might be our problem... If you get in water deeper than half your tire maybe less water can enter the intake and get into your engine cause it to make holes in the engine because water can't compress so it gets stuck in the pistons I think it is or cylinders I'm not sure. They just bust holes in the engine.. You can see them most of the time so try getting under there and checking it out..
Xaperez100 is offline   Reply With Quote
Old 05-29-2013, 07:05 PM   #7
Region: Arkansas
I don't have water damage. I was referring to everything else except that. My sea light doesn't come on but it hesitates and stalls if I turn in the air or my lights. I really need a solution to this problem ASAP
Old 05-29-2013, 07:23 PM   #8
Xaperez100's Avatar
So if you leave lights off and air off the car stays on?
Old 05-29-2013, 08:02 PM   #9
Region: Arkansas
Yes
Old 05-29-2013, 08:04 PM   #10
sam62893's Avatar
Might be a short. Could have gotten water in your fuse box or something in the engine.
Old 05-29-2013, 08:33 PM   #11
Region: Arkansas
My code was p 1233 so I wanted to know what the guy did to fix his car or whatever happened
Old 05-29-2013, 11:28 PM   #12
Xaperez100's Avatar
Hmm idk then maybe your ccrm messed up they sell them on eBay for like $50 way better than the 200 you pay from anywhere else
Old 05-29-2013, 11:35 PM   #13
Region: Arkansas
I looked they're all high
07:09 PM
