Just ordered springs - Mustang Evolution
Old 07-31-2012, 01:29 AM   #1
twotone01's Avatar
I just ordered the SR springs from AM
Hopefully they come soon! Not looking forward to the install but oh we'll haha anyone have pics with those actual springs?
twotone01 is offline   Reply With Quote
Old 07-31-2012, 05:07 AM   #2
Don't have those springs but the install is easy. I watched and followed a YouTube video
Blackedout is offline   Reply With Quote
Old 07-31-2012, 05:19 AM   #3
1slosix's Avatar
Re: Just ordered springs
Spring install is a super easy job....just have a friend handy
Old 07-31-2012, 06:54 AM   #4
kickerofdoom's Avatar
Depends mine had rust the most important thing is safety don't just force them out.
Old 07-31-2012, 07:54 AM   #5
1slosix's Avatar
Lol thats how i take them out....i grab the coil with my hand and give it a good pull
Old 07-31-2012, 11:30 AM   #6
twotone01's Avatar
The ones I'm worried about are the fronts haha the rears don't look too bad
Do I have to get new cotter pins of can I reuse them??
Old 07-31-2012, 03:02 PM   #7
1slosix's Avatar
Cotter pins? Where are you needing them? Pop the wheel off, unbolt the sway, pop off the caliper after removing two caliper bolts, unbolt the control arm from the shock...pop out the spring and reverse. Or are you trying to remove it a different way?
Old 07-31-2012, 03:37 PM   #8
I took the risk other than my arm getting thrown yanking the front spring out nothing else happened. Wasn't that bad after I got the tension off and let the a arm loose... Fun install tho.
Old 07-31-2012, 08:52 PM   #9
jrmustang02's Avatar
Region: Rhode Island
How much would a shop normally charge for the install of lowering springs?
jrmustang02 is offline   Reply With Quote
Old 07-31-2012, 09:02 PM   #10
1slosix's Avatar
too much when it's so simple to do yourself plus it's a good learning experience and you can really start getting a good feel for the car
Old 07-31-2012, 09:21 PM   #11
johnofarch14's Avatar
Send a message via Skype™ to johnofarch14
I paid 160 for labor here in illinois, that was 2yrs ago.
johnofarch14 is offline   Reply With Quote
Old 07-31-2012, 10:34 PM   #12
400-200 to install spring around me. I spend 40 dollars for a pry bar 5 foot tall to help me with the install
Old 07-31-2012, 10:44 PM   #13
So I'm guessing $400 is a typo
Old 07-31-2012, 10:44 PM   #14
twotone01's Avatar
Hmm ok haha I thought you had to remove the cotter pins
I guess not
I changed my cv axle on my f150 and had to remove some pins so I assumed it was the same in here but now that I looked at it I was way wrong
Old 07-31-2012, 10:45 PM   #15
Nope it was a mustang shop
Old 07-31-2012, 10:49 PM   #16
1slosix's Avatar
I guess not
makes sense....i had an f150 that i slammed back in highschool so i know your pain
Old 07-31-2012, 10:57 PM   #17
Well it can still be a pain mine had rust and broke off so working on cars isn't easy that what I learned so far
Old 07-31-2012, 11:02 PM   #18
1slosix's Avatar
may i ask what broke off?
Old 07-31-2012, 11:06 PM   #19
The bottom part of the spring too much rust
Old 07-31-2012, 11:08 PM   #20
1slosix's Avatar
lol good thing you replaced it then
Old 08-01-2012, 02:40 AM   #21
twotone01's Avatar
Looks like my spring isolator is shot too so I gotta go buy those now
It's all ripped in half
Old 08-01-2012, 07:40 AM   #22
I didn't use them
Old 08-01-2012, 08:15 AM   #23
twotone01's Avatar
I didn't use them
I was looking at my friends gt and he didn't have them either
Are they a must have?
Old 08-01-2012, 10:48 AM   #24
They are there for noise. I hear mine but with my music blasting its like there not there
Old 08-01-2012, 01:10 PM   #25
1slosix's Avatar
i don't run them...they lower the car 1/4"without them
Old 08-02-2012, 08:32 AM   #26
I don't use them either, I sprayed silicone lubricant on top and bottom of each spring one year ago, all squeaks gone.
Post some picks with new springs ASAP.
Old 08-02-2012, 10:41 AM   #27
twotone01's Avatar
Maybe I'll try that
Im just worried it'll squeak bad w/o them
I'll get pics as soon as I get them on
There still on their way from AM and I'll have to put them on at school haha
Old 08-03-2012, 06:02 AM   #28
Maybe I'll try that
I remember seeing that set on AM and reading that it's a slight drop. Just remember that if you go any lower, shocks/struts, caster camber plates, and then some, may be needed along with suspension shop work.
Old 08-03-2012, 05:04 PM   #29
Fourloko530's Avatar
What kind of springs u got
Fourloko530 is offline   Reply With Quote
Old 08-03-2012, 09:17 PM   #30
twotone01's Avatar
I got the SR lowering springs
Stack racing I believe
---------- Post added at 08:17 PM ---------- Previous post was at 08:17 PM ----------
Yeah that's why I wanted a mild drop
Old 08-03-2012, 09:24 PM   #31
U put em on yet
Old 08-03-2012, 09:53 PM   #32
twotone01's Avatar
U put em on yet
Na not yet the estimated delivery date is on Monday
Old 08-03-2012, 10:04 PM   #33
1slosix's Avatar
won't squeak unless you hit a bad speed bump and the rear shifts a bit thanks to the quad shocks
Old 08-03-2012, 10:31 PM   #34
twotone01's Avatar
I have a ton of speed bumps at the school I go to haha being an auto school a lot of people like to show off
Old 08-04-2012, 10:05 AM   #35
1slosix's Avatar
lol then make your exhaust louder...you'll never hear the light squeak
12:13 AM
