abs braking one tire only. i need help - Mustang Evolution
Old 07-31-2012, 09:48 PM   #1
Question abs braking one tire only. i need help
i have a 2001 ford mustang v6 3.8 im having problems with my abs. my abs is braking my left rear tire only any idea how to fix this problem
Marco is offline   Reply With Quote
Old 07-31-2012, 09:50 PM   #2
1slosix's Avatar
Re: abs braking one tire only. i need help
have you had an ABS scanner put on it yet? most autoparts can run ABS codes using the same scan tool they use for CEL readings
Old 07-31-2012, 09:55 PM   #3
i will go buy one to see the codes. i have the fuse removed so i can drive it.
Old 07-31-2012, 11:19 PM   #4
Krazy Horse's Avatar
U can check sensor with lab scope n watch for pattern to change or drop out when u spin by hand. Double check caliper slide pins if disc, or check for wet shoes if drum rear brakes
Krazy Horse is offline   Reply With Quote
Old 08-02-2012, 12:05 AM   #5
Ok i will check that u bough the scanner today but I didn't have time to check for the codes but on Friday I will check the pins and for codes and I let you know on Friday
Old 08-11-2012, 12:53 PM   #6
Well I got the scanner and I got a code that is about no comunication with the abs computer
Old 08-11-2012, 06:33 PM   #7
Sounds like that wheel sensor dropped out, or ur abs module is going bad
11:35 AM
