Turbo or build engine?? - Mustang Evolution
Old 08-01-2012, 05:51 PM   #1
Surffer227's Avatar
Have a 01 v6, CAI and a dumped exhaust. I have a small amount of cash to spend, should I try to do a cheap turbo kit? I saw a twin turbo kit on eBay for like 900 bucks but u need to make custom turbo manifold and down pipe, is that worth it? To run low boost on stock internals? Or shout I put a good 1500-2000 into my engine, I might do a overhaul or the turbo kit within the next few months, lemme know your opinions.
Surffer227 is offline   Reply With Quote
Old 08-01-2012, 05:53 PM   #2
Butch's Avatar
Region: New Mexico
Internals would be awesome, with that later down the road you can boost mad lbs, or more lbs with a lot less worry
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 08-01-2012, 11:07 PM   #3
kickerofdoom's Avatar
Build the engine
Old 08-01-2012, 11:17 PM   #4
NeedSomeMods's Avatar
Build that engine up with forged everything. Break it in while saving for FI.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 08-02-2012, 09:40 PM   #5
davidcseifert's Avatar
Region: Arkansas
Re: Turbo or build engine??
since no one has said it... ebay turbo kits equal grenades... but even if it was a good kit you still have to fab up the hotside which would cost a lot more than you want
btw you can put 11psi on factory internals without much worry
as for the motor work unless you plan on installing yourself (which isn't hard if you take your time) it'll also cost a lot, what exactly is your budget?
unless you have a lot of mileage i wouldn't worry about rebuilding it, maybe find a cheap low mileage 4.2 out of an f150 to drop in for a little increased displacement
if you're seriously considering motor work talk to kyle...
Home - Kyle Person Performance
he can get you good gains for a decent price
blower/new cam soon
Old 08-03-2012, 12:25 AM   #6
Surffer227's Avatar
Well I was hopin to spend around 1500-2000, I'm not a huge fan of boaring out my engine, just cause of the costs for all the new parts I'd need, I never looked to much into it, mabey someone can convince me it's worth it, I was thinkin along the lines of porting my heads, mabey a cam, balancing my piston heads and rods, mabey a few other things, I would do whatever labor myself, that's why I was thinkin of pulling the whole engine and doin a overhaul while I'm doin all the other stuff. Hate to strip it down 3-4 times just cause I found another part I wanna put in, just rather do it all at once.
Old 08-03-2012, 08:21 AM   #7
He knows his stuff about built engines and bolt on.
Old 08-03-2012, 09:21 AM   #8
1slosix's Avatar
Well at least kyle does lol....na i kid david. For NA he should be happy
Old 08-09-2012, 10:37 PM   #9
Region: Arkansas
-_- you son of a #%$^#%^#%^#$%#%^#%^#%^
jk
i've learned a lot about these cars with as many times as i have been inside the damn motor lol
blower/new cam soon
Old 08-09-2012, 10:43 PM   #10
1slosix's Avatar
yeah i could see how that'd be a side effect of having to tear it down so much.
Old 08-11-2012, 07:27 AM   #11
rinfield2004's Avatar
build the engine and go Supercharger later. Procharger highly recommended.
rinfield2004 is offline   Reply With Quote
06:56 AM
