brakes - need input - Mustang Evolution
Old 03-05-2008, 01:10 PM   #1
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
brakes - need input
I need brakes soon and I wasnt to upgrade to drilled and slotted. woudl these bo okay you think?
Brakes
if not where should I get some from?
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 03-05-2008, 02:11 PM   #2
Re: brakes - need input
Those actually aren't all that bad. But..if you are planning on really upping the power here in the future I might look into a 13 inch brake kit.
Old 03-05-2008, 02:17 PM   #3
arent those a good buck or two? where?
Old 03-05-2008, 02:42 PM   #4
drilled/slotted rotors are not an upgrade, they are a looks mod. They can also crack and warp depending on brand. I had a set on my old car and drove it easy and they warped in 20k miles.
Old 03-05-2008, 03:42 PM   #5
so the only brake "upgrade" is bigger then. where can I find a 13" brake kit?
Old 03-05-2008, 04:04 PM   #6
MonteCitan's Avatar
slotted rotors are an upgrade, drilled not so much unless as with baer and such, the holes are designed into the rotor rather than simply added on
I use powerslot rotors and Hawk HPS pads on the buick, stopping power increased tenfold, and 35k + miles of hard driving on the rotors, on the second set of pads, and no warpage yet
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Want some input iwannagofast The Bar 11 11-23-2007 05:23 PM
Building PC help/input SpectorV The Bar 11 11-08-2007 09:16 PM
Need some input... crazeflier07 Mustang Wheels & Tires 6 10-03-2006 09:57 AM
Mainly for Corey but anyone else that has input.... Brent Pre-2005 V6 Mustang 60 04-20-2005 11:51 PM
Your input is valuable John Kerry The Bar 33 09-18-2004 11:02 PM
08:11 AM
