Sequential tail lights HELP - Mustang Evolution
Old 08-05-2012, 06:22 PM   #1
Jetsnix's Avatar
I ordered the sequential tail light kit from american muscle a few days ago, I spliced them in today, the right light works fine. On the left, I noticed (after I blew about 3 fuses) that one of the wires got pinched to the body by one of the screws on the tail lights, and it was shorting. Now that I fixed that, the left side doesnt sequence right. Everything is installed right, they were working perfectly before the wire got pinched. Is there any way to fix this?
04 V6 Coupe Divorced flow 40's, AM CAI, Dual Rockford Punch 10 in. Subs, Matrix 1500 Watt Amp, Infinity speakers
Jetsnix is offline   Reply With Quote
Old 08-05-2012, 06:24 PM   #2
Lorraine's driver
ab_mach1's Avatar
Is there any kind of fuse in the sequential harness that might have blown along with the others that you fixed already?
Instagram: @ab_mach1
Old 08-05-2012, 06:28 PM   #3
Jetsnix's Avatar
Re: Sequential tail lights HELP
Havent checked, kinda dont wanna open it up and possibly mess it up more.
Old 08-05-2012, 06:52 PM   #4
Lorraine's driver
ab_mach1's Avatar
Do all the lights work, but they are just not in order?
Old 08-05-2012, 06:55 PM   #5
jimmy_beaner's Avatar
Region: Iowa
Yeah, it sounds like they aren't in the right order... which is as easy as changing the order. Otherwise... you may have damaged the circuitry
You can check the order easily by only hooking up two of the three, and just see what order they pop in. 2 or 3 cycles and you'll be sure of the order. Conversely, you can also cover up one of the three, several times. (By someone that's installed them)
Old 08-05-2012, 06:56 PM   #6
Lorraine's driver
ab_mach1's Avatar
And it's too bad Ford designed it so you would have to take the whole light assembly off to change bulbs, etc.
Old 08-05-2012, 06:59 PM   #7
Jetsnix's Avatar
They all work, but instead of the first one going, then middle light, then outer light, it lights up with the first two at the same time, then the outer light lights up. I figured that i damaged the circuitry as well. Is there anywhere i can just get a single splice circuit?
Old 08-05-2012, 07:14 PM   #8
Region: Iowa
Can you take a video? I mixed up the order once and it looked like two were going off at the same time... but actually middle then inner then outer was firing. The weird order made it look like middle and inner fired at the same time with a longer delay for outer. You could always pull the cover off the circuitry and see if something blew (assuming you know how to do circuit boards).
Old 08-05-2012, 07:33 PM   #9
Jetsnix's Avatar
I can take a video tomorro, cant tonight though. From what i know, it looks exactly the same as the right side, but im not sure. My brother helped me out, and he ended up being the one messin it up
Old 08-06-2012, 09:12 AM   #10
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Jetsnix,
I'm sorry to hear about the issues your experiencing. I agree with everyone so far, it sounds like somethings definitely going on with either the pinching of that line or the order of the bulbs. Once you post up the video we may have a better idea on the second option.
Let me know if you have any questions. If you need further assistance, Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
- Dan
Old 08-06-2012, 09:41 AM   #11
Jetsnix's Avatar
Originally Posted by AMDanBailer View Post
Jetsnix,
- Dan
thanks man, I tried calling the number on the instructions, but no good.
The video is processing right now, once its done ill post it
EDIT:
Old 08-07-2012, 10:30 AM   #12
AmericanMuscle.com
Sponsor
EDIT:
Jetsnix,
Okay I see what you're talking about now, thanks for posting the video. Regardless of the situation we'll never leave a customer behind, we can definitely take care of you here. Shoot me a PM with your order # included & I'll have one of my best guys contact you directly.
If you need immediate assistance, Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
- Dan
» Members Mustangs
Grace
matcox83
Sexy
Alex117
Add your Mustang
09:38 PM
