reinstall kick panel - Mustang Evolution
Old 08-06-2012, 06:25 AM   #1
willrad00's Avatar
So i had to take the passenger side kick panel to get to my computer code for my tuner, and now i have no idea how to put it back on. does the bottem door sill pop out with clips also?
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 08-06-2012, 06:30 AM   #2
xhgwx's Avatar
Push the kick panel back in, should have a clip in a hole, line the clip up with the hole and push quite hard and should pop in. Then put then door sill on, same thing, line it up, push hard, will pop right in. Hope this helps!
xhgwx is offline   Reply With Quote
Old 08-06-2012, 03:45 PM   #3
willrad00's Avatar
Re: reinstall kick panel
So the door sill just pops right out with clips also?
Old 08-06-2012, 04:57 PM   #4
xhgwx's Avatar
Yes sir, just get under it a little with ur fingers and pull straight up
Old 08-06-2012, 06:29 PM   #5
willrad00's Avatar
ok, thanks guys!
Old 08-06-2012, 06:39 PM   #6
davidcseifert's Avatar
Region: Arkansas
i did the same thing the first time lol
btw your computer code should also have been on your door jam sticker
blower/new cam soon
01:38 AM
