need help b4 i make a mistake 3.8-3.8 - Mustang Evolution
Old 08-11-2012, 11:16 AM   #1
Region: Iowa
So i have a 99 3.8 mustang 199,000 miles on it and i got it for real cheap because the motor is not in best shape.i have found a 3.8 mustang engine for sale out of a 00. It had 48,000 miles on it and asking$700 . I'm wanting to know is what complications would there be with this swap? Does everything from the 99 fit the 00?
brettthom1422 is offline   Reply With Quote
Old 08-11-2012, 11:41 AM   #2
Re: need help b4 i make a mistake 3.8-3.8
If it is the exact same motor then it should be a pretty easy swap.
Old 08-11-2012, 01:15 PM   #3
ProjectTurboV6's Avatar
Exact same motor so it fits perfect, but you can find a 4.2 out of a 2000 f150 for the same price, with some more kick. Just something to think about.
ProjectTurboV6 is offline   Reply With Quote
Old 08-11-2012, 01:45 PM   #4
Region: Iowa
I didn't know that.. Will it still b as straight forward? and would i need to get a lot of other parts?
Old 08-11-2012, 01:48 PM   #5
Still the same motor, just diff heads with diff bore. You would have to take its fuel pump aswell as the wiring harness.
Old 08-11-2012, 02:34 PM   #6
Region: Iowa
That's pretty interesting.
Old 08-12-2012, 02:37 PM   #7
Region: Iowa
Might be a dumb question but does it matter if i get the engine from a automatic or manual
Old 08-12-2012, 03:24 PM   #8
V6 stang's Avatar
I would think so lol
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 08-12-2012, 06:25 PM   #9
Dgerow12's Avatar
I don't believe the engine matters or you would not be able to do swaps on cars. What matters is the ecu. The ecu has all the shift points and running info on it
Dgerow12 is offline   Reply With Quote
Old 08-12-2012, 10:55 PM   #10
Region: Iowa
I got the right ecu.just trying to figure out if either of the engines will bolt up to a manual.
Old 08-13-2012, 06:33 AM   #11
Doesnt matter at all. The only thing that is diffrent between an auto and manual is the transmission
Old 08-13-2012, 09:03 AM   #12
Dgerow12's Avatar
And the ecu for manual to auto swaps cause of shift points
Old 08-13-2012, 10:59 AM   #13
Cblackstang's Avatar
Engines make no difference..I had an auto in mind then swapped to a 5 speed only had to change the ECU
Cblackstang is offline   Reply With Quote
Old 08-13-2012, 02:13 PM   #14
Region: Iowa
Sweet that is good to know. Thanks for the help
06:24 AM
