3.8 dies in hot weather - Mustang Evolution
Old 08-12-2012, 02:30 AM   #1
Region: Arkansas
Hi guys ive been having have issues with my 96 mustang 3.8. When its really hot outside like high 90s, my car stumbles and dies after about 30 mins. Sometimes it will restart and I can drive it for another min before it dies again but usually Ill have to let it cool and then it starts in runs the cycle again. Ive done some searching and found this to be a very common problem with all mustangs and based on symptoms of other ive narrowed it down to either the fuel pump or the tfi module. Only thing is the 96 and up mustangs dont have a tfi module do they? Did ford replace it with something similar and change its name or what else should I look for? any help is appreciated.
texasfinest1 is offline   Reply With Quote
Old 08-12-2012, 09:27 AM   #2
joey18's Avatar
Mine was doing that and i figured out my cooling fan wasnt coming on. id drive the car and it would heat up and stop. I changed the fan and then everything was fine, ir could be that and if it is id be alooot cheaper to fix
joey18 is offline   Reply With Quote
Old 08-12-2012, 03:26 PM   #3
V6 stang's Avatar
Need more info. Is your temp gauge rising as your car is on?
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 08-12-2012, 04:58 PM   #4
Region: Arkansas
Re: 3.8 dies in hot weather
my gauge does rise above what I think is normal but i dont know. Always was like this from the day I bought it. It rises over to the "m" and "a" on the hand. but fan kicks on it cools it back down. My ford truck on the other hand never gets above half on the temp gauge and that goes for any other car Ive ever owned
Old 08-12-2012, 05:12 PM   #5
joey18's Avatar
Does the radiator have and leaks? Is your coolant level good?
Old 08-12-2012, 05:49 PM   #6
Region: Arkansas
coolant level is good. no leaks anywhere
Old 08-12-2012, 10:21 PM   #7
1slosix's Avatar
could also be the ignition module...if its going faulty when it overheats it'll cause the car to shut down. they can be tested at any autoparts store. just another idea if the fan thing doesn't play out
Old 08-13-2012, 09:10 AM   #8
V6 stang's Avatar
Does the engine run rough when it is on?
Roush Exhaust
Old 08-13-2012, 11:52 PM   #9
Region: Arkansas
It runs really well except when it starts to act up like its starving for fuel..bucking and jerking and if I push the gas it dies.. It may start back up but barely still bucking... Have to let it cool down and it's fine for another 20 to 30 miles... But I can drive it all night long without any problems.. Only does it when it's really hot
Old 08-14-2012, 08:48 PM   #10
V6 stang's Avatar
Kind of sounds like fuel pump. Maybe it has a defect so when it gets hot it stops working right. I know things can do that. My dads boat motor had a starter cylinoid that did it.
Roush Exhaust
Old 08-14-2012, 10:55 PM   #11
joey18's Avatar
The start up problem does sound like a fuel pump. On my old car that was happening, id start up and it sounded like it was starving for gas and i replaced the fuel pump and it stopped doing that.
Now i dont know why itd only be doing it when its hot?
Or does it do this all the time when you start up?
Old 08-15-2012, 02:50 AM   #12
Region: Arkansas
Only on really hot days after driving 20 to 30 miles
Old 08-15-2012, 06:29 AM   #13
V6 stang's Avatar
Sometimes there will be something wrong inside of it and heat can kill it. When it cools down it can be ok though. Change fuel pump or take it to a mechanic and report back
Roush Exhaust
06:24 PM
