Best size? - Mustang Evolution
Old 08-12-2012, 10:20 PM   #1
Mike V.'s Avatar
Best size?
What do you guys think the best size rims and tires are for a 99 v6 stang
Mike V. is offline   Reply With Quote
Old 08-12-2012, 10:23 PM   #2
1slosix's Avatar
Re: Best size?
i like 17x9's all the way around...it's my favorite setup and give you plenty of traction with some good tires, but not alot of rotational mass
Old 08-13-2012, 01:00 AM   #3
slow281
sixpac's Avatar
Region: Nebraska
Anyone have pictures of 17.x9 all the way around and 17x9 with 17x10.5 staggered
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 08-13-2012, 01:29 AM   #4
BeasGT's Avatar
17x9 all the way around
BeasGT is offline   Reply With Quote
Old 08-13-2012, 02:37 AM   #5
Horseplay's Avatar
17 x 9 front
17 x 10.5 rear
best decision i made for my car
Low2v
Old 08-13-2012, 09:12 AM   #6
rinfield2004's Avatar
Re: Best size?
18x9s all way round.
rinfield2004 is offline   Reply With Quote
Old 08-13-2012, 09:14 AM   #7
ProjectTurboV6's Avatar
Truthfully 16/45/235 all the way around is the best option. Lighter rims but still a fat tire to put the power on the ground. We have v6s so we really dont need that big of a rim/tire.
ProjectTurboV6 is offline   Reply With Quote
Old 08-13-2012, 12:08 PM   #8
1slosix's Avatar
Re: Best size?
i can say this with all honesty...v6 16's are heavy wheels. in fact my '04 v6 16's are way heavier with a mounted 225 then the '99 GT 17x8 wheel's i'm installing with a 245 on them. in fact i'd argue that the rear 275's on those wheels are still just as light as the oe 16
Old 08-13-2012, 12:36 PM   #9
[QUOTE="1slosix"]
i can say this with all honesty...v6 16's are heavy wheels. in fact my '04 v6 16's are way heavier with a mounted 225 then the '99 GT 17x8 wheel's i'm installing with a 245 on them. in fact i'd argue that the rear 275's on those wheels are still just as light as the oe 16 [/QUOTE
Please explain how a 17in will weigh less than a 16. It's more material, its bigger around so it takes more to make it move, I mean it looks better no doubt about that. But depending on the type of material stock rims are atleast 5lbs lighter.
http://www.allfordmustangs.com/forum...ht-thread.html
---------- Post added at 12:36 PM ---------- Previous post was at 12:31 PM ----------
Idk what happened with that ^ but for the record, not trying to argue. Just curious.
Old 08-13-2012, 12:44 PM   #10
1slosix's Avatar
Re: Best size?
material is everything and the amount used...a 99 GT wheel only weighs 22 lbs...i wieghed my sixxer wheels at 28 lbs. that's 6lbs of rotational mass difference for a little sixxer to push
Old 08-13-2012, 12:50 PM   #11
But I thought the stock rims were aluminum?
Old 08-13-2012, 12:52 PM   #12
1slosix's Avatar
Re: Best size?
on an '03- '04 they have a chrome like plating that really weighs them down. on the 1/8th i shaved off some time just from swapping from my 16s to some gt 17s alone
Old 08-13-2012, 01:01 PM   #13
I have a 98... Plus it only gives yuh like 2rwhp for swapping rims. Our power to wait ratio is around 15
Old 08-13-2012, 01:08 PM   #14
1slosix's Avatar
Re: Best size?
slight bit of hp and tq difference for basically the same weight overall between an sn95 and new edge.
Old 08-15-2012, 03:20 AM   #15
Mike V.'s Avatar
So if I got 17x9s I could just swap them out with no problems or mods?
Old 08-15-2012, 06:13 AM   #16
Dgerow12's Avatar
As long as you run proper sidewall hieghts everything will work fine if not your speedo may be off alittle
Dgerow12 is offline   Reply With Quote
05:29 PM
