2003 3.8 injectors - Mustang Evolution
Old 08-15-2012, 01:43 AM   #1
Mr_Trigger3.8's Avatar
2003 3.8 injectors
Anybody know what injectors can be used in the 3.8? I want to upgrade them but not quite sure how much lbs would be best. Or if I can swap ones from another ford.
Mr_Trigger3.8 is offline   Reply With Quote
Old 08-15-2012, 06:12 PM   #2
davidcseifert's Avatar
Region: Arkansas
Re: 2003 3.8 injectors
why are you upgrading? you won't gain any power from it, factory size is 21#
blower/new cam soon
Old 08-15-2012, 08:24 PM   #3
I'm going to be Swapping heads, cams, valves, lifters and all that good stuff. So I was just seeing if I could get any higher lbs injectors for decently cheap.
Old 08-16-2012, 12:06 AM   #4
Region: Arkansas
swapping as in doing like mine? to what extent are you going per say? i still use the factory injectors, but the common upgrade is just some 24's if you think you'll need them
blower/new cam soon
Old 08-16-2012, 12:31 AM   #5
What'd you do to yours? I'm buying ore built heads off supersixmotorsports.com. I was just curious if anyone's swapped injectors. I was looking for some that we're interchangeable to the 03 3.8s.
---------- Post added at 12:31 AM ---------- Previous post was at 12:30 AM ----------
Because from what I've heard if you swap cams it's a good thing to upgrade injectors as well.
Old 08-16-2012, 12:39 AM   #6
Region: Arkansas
it's all in my signature
might i suggest somewhere else to make it a little easier on your pocketbook? lol
Home - Kyle Person Performance
he does good work, he made my new cam and is making me a set of upgraded heads from the stage 3 SSM heads on my car and it's gonna be cheaper than 1750 for a set of heads
and sure you can search ebay/corral.net/etc. for some 24# EV6 injectors usually find them for around $70-$80 for a set of 8
blower/new cam soon
Old 08-16-2012, 03:05 AM   #7
ForsakenProto's Avatar
Im throwing some 24# injectors in mine tomorrow, gonna contact bama about adjusting my tune for them.
ForsakenProto is offline   Reply With Quote
Old 08-16-2012, 10:57 AM   #8
Sweet thanks. Yea I'll have to check them out. Ate the cams and heads he make street legal? I live in Cali so the regulations are a *****. And I'll check out those 24#s.
Old 08-16-2012, 11:36 AM   #9
Region: Arkansas
LOL street legal yes, emissions legal no but then again no cam is emissions legal in the retarded world of Cali regulations, but talk to him and I'm sure he can work something out for you
blower/new cam soon
Old 08-16-2012, 11:52 AM   #10
California is the devils land. It just needs to float away from the rest of the US
Old 08-18-2012, 02:14 AM   #11
It's supposed to eventually. Haha were gonna go kick it with Hawaii.
11:07 PM
