under pulleys - Mustang Evolution
Old 03-11-2008, 02:26 PM   #1
sparkylarue's Avatar
Region: Utah
under pulleys
When replacing under pulleys, what exactly do you lose? I understand that you gain HP by freeing the power up from the accessories, but what exaclty does that mean? how are the "accessories" affected?
Any jackass gets aboard one and runs it from hell to breakfast, blowin' his whistle to beat the band and tellin' the rest of the world to look out for him, because he's comin' and can't look out for himself!
Jack London - The Sea Wolf
sparkylarue is offline   Reply With Quote
Old 03-13-2008, 09:55 AM   #2
Re: under pulleys
The biggest problem I have ran into is that I have to be on the Highway for the ac to work very well. In traffic my AC is only slightly cool on the highway it will turn you into an ice cube. Something to think about if you don't want your girlfriend sweating...lol or should I say B*tching about it. I did get a high output alt with very small pulley to keep the charge up so that may also be a problem if you are running a system and using juice there.
partanimal911 is offline   Reply With Quote
Old 03-14-2008, 07:30 AM   #3
Re: under pulleys
Basically it takes power to make power. You are using the belt that is being turned by the crank to turn all of the other things. If you slow this down it takes less power to turn them as they dont turn as fast. Like it takes less gas to go 100mph than it does 75mph. A 25% underdrive pulley will slow them down by 25%.
The only real issues you should see is if you have a stereo system it might have issues staying charged at idle and maybe some not as cold AC if you are sitting idling.
You gain a bit of gas mileage though.
Old 03-14-2008, 10:57 AM   #4
Herbstang's Avatar
Re: under pulleys
Never had any power or A/C issues with my pulley
Old 03-15-2008, 01:07 AM   #5
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Re: under pulleys
same here
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Pulleys! gasteven Pre-2005 V6 Mustang 16 04-15-2010 11:25 AM
Pulleys SaturnMan8227 Pre-2005 V6 Mustang 12 01-19-2009 02:18 PM
Under drive pulleys, should I or shouldn't I? microflight 1996-2004 Mustang GT 32 07-30-2007 12:31 AM
UD Pulleys mexor 1979-1995 Mustang GT 5 08-11-2004 06:46 PM
UD Pulleys RedDragonV6 Pre-2005 V6 Mustang 8 02-20-2004 12:29 PM
12:04 PM
