Help replacing rotors - Mustang Evolution
Old 08-16-2012, 12:04 AM   #1
willrad00's Avatar
Hey guys, put the mustang in the ditch bout a week ago and long story short i need knew rotors. Anyone hav a good step-by-step guide i could follow? I checked AM, but they didnt hav much. Thanks guys
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 08-16-2012, 12:15 AM   #2
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
What year is your mustang?
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 08-16-2012, 12:34 AM   #3
davidcseifert's Avatar
Region: Arkansas
Re: Help replacing rotors
greg it's in his sig lol
replacing them is simple
pop off the wheel
remove the two bolts attaching the caliper to the caliper bracket (ziptie the caliper out of the way so it isn't hanging by the brake line)
then remove the two bolts holding the caliper bracket on
then you can just pop the rotor right off
when you go to re-install the front calipers you can use a C-clamp to compress the pistons back into the caliper to make it easy to slide the caliper back on
the backs require a little trick though, you must apply pressure to them while spinning them (clockwise i believe) to make them compress back in
blower/new cam soon
Old 08-16-2012, 03:04 AM   #4
alrefire's Avatar
make sure you pump the brakes when you your calipers back on. the last thing you want is non-functional brakes!
Old 08-16-2012, 06:08 AM   #5
gregtommy's Avatar
Yeah I can't see sigs on the iPhone app sounds like you got it though. I just did a front brake joh on a 2001 cobra
MOTM DEC 2011
Old 08-16-2012, 06:25 AM   #6
Just to add, you might need a mallet or hammer to get the rotor off, they usually rust and get stuck quick well... lol. Just bang it around the exposed metal and it'll fall off!
Fox Fan is offline   Reply With Quote
Old 08-16-2012, 06:50 AM   #7
gregtommy's Avatar
+1 spent twenty minutes beating the rotors off an 01 cobra lastnight
MOTM DEC 2011
Old 08-16-2012, 08:47 AM   #8
Region: Arkansas
Gah whats wrong with you guys I usually just use two hands to yank that puppy outta there? Lmao nah mine have never been stuck actually
blower/new cam soon
Old 08-16-2012, 02:49 PM   #9
Blogger
99ford's Avatar
+ a billion..
---------- Post added at 04:49 PM ---------- Previous post was at 04:40 PM ----------
And get some CRC Green brake parts cleaner that's Ford says to use green, I use the red. Paper towels, and a brush then brush the old crap out and clean up the piston (rear)/pistons( front) real good. Also lube the guide pens and make sure to smother and cover the position, and pads with hi temperature grease.
Also make sure you got some ventilation when the CRC gets applied it can make you a bit light headed otherwise.
Old 08-18-2012, 03:08 PM   #10
willrad00's Avatar
So i changed pads and rotors on one side and the back side pad was worn to the metal and then i couldnt get the caliper on... Didnt occur to me that the piston was probaly seized. So i finally got the caliper on and drove it to the shop, while my brakes smoked the whole way. Now I need new calipers, another new rotor, and new pads on that side AGAIN.
Old 08-18-2012, 05:24 PM   #11
Blogger
99ford's Avatar
You shouldn't need a new rotors and pads. How far is the shop? unless it stuck so bad it all melted.
Old 08-18-2012, 10:13 PM   #12
willrad00's Avatar
all melted, but i'm gonna hav them try to grind the rotor down to save some money.
01:39 AM
