Laser Spark Plugs - Mustang Evolution
Old 08-16-2012, 08:30 AM   #1
AK6
AK6's Avatar
Laser Spark Plugs
Anyone ever use 'em?
If so, results?
AK6 is offline   Reply With Quote
Old 08-16-2012, 08:34 AM   #2
Just use motorcraft/autolite copper plugs. Anything else is just wasting money
Old 08-16-2012, 08:45 AM   #3
AK6
AK6's Avatar
Re: Laser Spark Plugs
Very good. I appreciate it
Old 08-16-2012, 08:56 AM   #4
Mike SVOR's Avatar
I know the whole subject of sparkplugs can become a wild internet conversation, but imho, i'd stay away from autolite.
I run 28 lbs of boost in my other mustang and have had multiple failures of autolite plugs through the years. I've stayed away from them since.
Now if you're looking for a great plug that lasts long, get some platinum plugs. You can't go wrong. (they just dont work so well on boosted applications).
1999 3.8 stang
1990 LX - supercharged 351w
1985 turbo 2.3 www.msvorinich.itgo.com
Mike SVOR is offline   Reply With Quote
Old 08-16-2012, 09:02 AM   #5
AK6
AK6's Avatar
I've been told that even though platinum can and probably will last up to twice as long as copper, they can also be more fragile.
How does that play out in a place like Michigan where we go sub-arctic temps by October?
Old 08-16-2012, 09:07 AM   #6
I'm pretty sure op isn't running 24lbs of boost. Personally I run ngk tr6 copper plugs
Old 08-16-2012, 09:43 AM   #7
deadsp0t's Avatar
Not only that, but copper is proven time and again the best choice.
Platinum plugs suck.
That's unimpressive
Old 08-16-2012, 09:43 AM   #8
Mike SVOR's Avatar
More fragile? They're made with porcelain and platinum.
Porcelain like normal plugs and platinum like what’s in your cats.
Not sure how they'd fail in cold weather. Never heard that one before.
1999 3.8 stang
Old 08-16-2012, 09:50 AM   #9
AK6
AK6's Avatar
That's why I take my time, because I don't know enough on my own. But I'm learning. Plus, I learn from guys like you.
How about if my OEM calls for iridium (non-mustang), can I switch to copper?
Or should I stick with what the oem calls for?
Old 08-16-2012, 09:51 AM   #10
Mike SVOR's Avatar
Please elaborate on how platinum plugs suck.
They come factory equipment on MANY cars and outlast copper in wear/erosion.
1999 3.8 stang
Old 08-16-2012, 09:56 AM   #11
AK6
AK6's Avatar
I just found that article. Definitely didn't say they suck, just that "the overall performance will not be as good and you may have to deal with overheating of the plugs."
Here the guys in the comments get on him a little bit too
And that's exactly why I seek out multiple opinions
I don't remember where I saw the weather thing, maybe my imagination.
Old 08-16-2012, 10:06 AM   #12
deadsp0t's Avatar
Exactly... I burnt a set of Bosch platinums down in a months time. They are snake oil IMO and you are welcome to 'my share'..
I don't and won't have any links to others opinions or anything of that nature, just my exp over the years..
That's unimpressive
Old 08-16-2012, 10:12 AM   #13
Mike SVOR's Avatar
I was quoting deadsp0t's post on his "suck" comment.
The info in that link you posted should probably be taken with a grain of salt.
He's saying copper doesn't melt like platinum plugs do. LOL
BIG difference in copper and platinum melting points.
but anyways....
I'm a copper plug fan and only put platinum into my stock truck so I don't have to change them for a while.
I run copper in everything else.
A nice set of NGK plugs should last 30 to 50 K miles. Realistically, i've pulled out copper plugs from people's cars with 100K on them.
1999 3.8 stang
Old 08-16-2012, 10:26 AM   #14
Also for what it's worth I pulled the oem platinum plugs from my focus at 50k and replaced with autolite coppers. Over the last 33k miles I have averaged the same or better fuel economy.
Old 08-16-2012, 10:31 AM   #15
AK6
AK6's Avatar
that's worth a lot actually
thanks
guess I'm learning to BEWARE THE HYPE
Old 08-16-2012, 06:27 PM   #16
deadsp0t's Avatar
but anyways....
So you like copper or platinum?
That's unimpressive
Old 08-17-2012, 09:11 AM   #17
Mike SVOR's Avatar
I use both.
Since I go through plugs every 6 months in my turbo mustang, I run a #8 NGK standard plug. I've actually never tested platinum on that car so I can only relay what others at theturboforums have documented in their use on boosted cars.
On my 84 stang, when it was naturally aspirated, i ran the msd with an accel supercoil. It would go through standard plugs once a year. That was a heavy duty spark coming out of that setup. I put platinums in and they lasted 2 yrs until I broke one taking the headers off. Ran standard plugs after that looking for a heat range change.
For my f150 platinum were factory equipment, and they lasted 115k miles before I changed them out. So they worked great in that scenario.
Like I said previously, theres nothing wrong with them on a stock to lightly-modded (non-boosted) engine. They last way longer than standard plugs and for the person that doesn't have a time or the tools to change plugs, taking it in for a plug change to platinum ensures you wont have to do it again for a long time.
and IIRC the older cobras came stock with platinum plugs also.
1999 3.8 stang
11:34 PM
