Cutting stock springs - Mustang Evolution
Old 08-17-2012, 07:59 AM   #1
Dgerow12's Avatar
As wondering if anyone had a how to or a link to one. I can't seem to find one for some reason...
Dgerow12 is offline   Reply With Quote
Old 08-17-2012, 08:25 AM   #2
It's not recommended but not hard. Remove the spring and use a cut off wheel to remove however much you want. Match for the other side.
If you take off more than 1 coil your ride quality will greatly suffer
Old 08-17-2012, 08:28 AM   #3
Re: Cutting stock springs
dont us a torch etc just a cut off wheel, i wouldnt cut more than one coil
Old 08-17-2012, 08:37 AM   #4
Btw, I bought a grinder and just picked up a cut off wheel for it
Old 08-17-2012, 10:01 AM   #5
Torchredmustang's Avatar
PM 1slowsix... He's done it a few times. He'll be able to help you with this one.
Torchredmustang is offline   Reply With Quote
Old 08-17-2012, 10:33 AM   #6
Dgerow12's Avatar
Ok I will. I'm only gunna remove one coil cause I heard one coil will give about an inch drop and that's what I'm looking for. Just slightly better stance and handling ability
Old 08-17-2012, 10:34 AM   #7
cant add back can only cut more so just be sure to not go to far with it (even though OEM springs are cheap to buy)
Old 08-17-2012, 11:55 AM   #8
Dgerow12's Avatar
Very true Spector very true
Old 08-17-2012, 04:44 PM   #9
mattyp511's Avatar
Region: New Mexico
Buy the proper lowering Kit don't go cheap an cut springs! Ur ride quality will go down!
mattyp511 is offline   Reply With Quote
Old 08-17-2012, 06:53 PM   #10
Eh...somewhat true. Running a set of cut v6 springs on the back of my cobra at the moment
Old 08-17-2012, 07:24 PM   #11
Horseplay's Avatar
i can cut my aftermarket springs a bit right ? i want more low
Low2v
Old 08-17-2012, 11:24 PM   #12
1slosix's Avatar
ok time to fix some mis information on cutting stockers
give me a few minutes im gonna be typing a while
Old 08-17-2012, 11:26 PM   #13
infamous281's Avatar
Do it.. Just cut a coil off and measure it right they are easy to cut too .
---------- Post added at 12:26 AM ---------- Previous post was at 12:25 AM ----------
I cut my aftermarket springs and didnt put insolators back in and got a good drop and no problems or noise.
So did my friend with his Ford C Springs
Old 08-17-2012, 11:31 PM   #14
1slosix's Avatar
ok any spring from fox bodies to an '04 i have cut without issues...
to cut them you'll want an angle grinder with a metal or bi-metal cutting wheel. a good wheel and you wont heat up the springs even close to enough to damage the temper. NEVER USE A TORCH
now for a new edge i have tried a few cuts...1 coil is safe for someone scared but my favorite stance takes away 1.25 coils off th efront and 1 coil off the back. you can leave your ISOs (isolators) but it's really pointless lol. i just use some electrical tape and wrap the ends (just to keep any squeaks from happening)
that setup is about a 1.5" drop on the front and 1.25" drop on the back...giving it a sexy stance
Now for why i'd use cut springs over aftermarkets...the ride for one can be a bit better since it's not as stiff. it also shifts weight better then most aftermarkets...so drag guys love it. in fact some of the fastest cars i know run cut stockers with a drag bag then anything
if anyone has any questions on how to cut them or even pics ( i think i have some) just pm me....
btw if you want a really good drag spring and dont mind a slight bounce then get some 4cly fox springs
Old 08-18-2012, 07:12 PM   #15
+1 on the 4 banger fox springs...a nice alternative to aftermarket springs if your pocket's feeling light.
Also on a side note....I'd rather cut my OEM linear rate springs than buy those rediculous ebay 2.5" springs that sag and give out after a year anyday.
Old 08-18-2012, 08:44 PM   #16
1slosix's Avatar
yep
and after running stockers cut for years i never had a sag issue
Old 08-30-2012, 12:14 AM   #17
Spiney's Avatar
I have a 96 Cobra. I want to lower it for better handling. A few questions: Are Cobra springs any different than stock V8 springs? How much work is involved in changing out the springs? If I cut 1 coil do I need to add a camber plate to get the car properly aligned? Thanks, Dave
Spiney is offline   Reply With Quote
Old 08-30-2012, 04:27 AM   #18
jdavis96gt's Avatar
Region: West Virgina
Cut 3/4 coil from TOP of back. Cut one coil from bottom of front. I think that's how it goes, anybody?
Old 08-30-2012, 10:19 PM   #19
1slosix's Avatar
i prefer 1.25 off the front and 1 off the back
Old 09-01-2012, 01:50 PM   #20
jdavis96gt's Avatar
Did u need camber plates or just the bolts for that much of drop?
Old 09-01-2012, 02:32 PM   #21
1slosix's Avatar
no it'll sit you close to 1.5" drop on the front and 1" on the back...no need for for plates or bolts just yet
12:04 AM
