pure engine or turbo power? - Mustang Evolution
Old 08-24-2012, 12:55 PM   #1
So I'm at the point where idk if I should try to get as much power out of my engine just by upgrading internals, bolt ons, boring cylinders, etc. Or if I shuld build the car for a turbo. Can anyone tell me what both will exactly entail, which will be cheaper, and can I go from a pure power engine to adding a turbo later? All the help is appreciated. Thank you.
morthis32 is offline   Reply With Quote
Old 08-24-2012, 02:58 PM   #2
Jetsnix's Avatar
Re: pure engine or turbo power?
I dont know much about motor building, or turbochargers, but I honestly like the idea of being fast with all motor. Kind of like being strong without using steroids is how i look at it. Not downtalkin turbo's but thats what i like about the newer boss 302's. All motor, all muscle.
04 V6 Coupe Divorced flow 40's, AM CAI, Dual Rockford Punch 10 in. Subs, Matrix 1500 Watt Amp, Infinity speakers
Jetsnix is offline   Reply With Quote
Old 08-24-2012, 03:48 PM   #3
Ya I like that too. But how much power can I get just using 3.8 V6 power?
Old 08-24-2012, 04:13 PM   #4
I feel that way with nitrous,,but the good thing about turbos and chargers,,is you can pretty much drive it everyday without killing your gasmileage ,,but have the power when you want,,When you build a engine thats capable to the power of tubos and chargers,,youll better off making it a track car...Thats why i dont mess with old engines and carbs,,because i want something fast and something i dont have to trailer around..I had a fast chevelle i built,,but you couldnt drive it on the street
mymustang is offline   Reply With Quote
Old 08-24-2012, 06:17 PM   #5
Jetsnix's Avatar
^^ i hear you on that, an exhaust, CAI, and a tune up and maybe a throttle body is the farthest i'm gettin into my engine.
You'd be surprised
Old 08-25-2012, 12:38 AM   #6
1slosix's Avatar
N/A the most i've seen is under 250rwp...with a power adder i've seen over 500 online...and about 400rwhp in person, but that's using an m112 not a turbo setup
Old 08-26-2012, 12:19 PM   #7
willrad00's Avatar
Honestly, if you buy a turbo most people will be satsified with the power on stock internals you wont need to build the engine. I've heard anywhere from 8-12 lbs of boost being safe stock, but either way your looking at low to mid 300's for hp with stock internals.
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 08-26-2012, 11:35 PM   #8
davidcseifert's Avatar
Region: Arkansas
if you do N/A build it'll be more costly for less HP but it's always fun to learn the motor from messing with it lol
if you choose to build the motor first and are 100% certain you will turbo later, make sure you get the right cam for a turbo setup, or run a good N/A cam and then switch out to a turbo cam when it's time to drop in a blower setup
are you in the market to buy now or planning for the future?
here's a good place to get motor parts and such from for a good price
Home - Kyle Person Performance
Mr.redpony had 271 rwhp (std) on MM with an N/A build
N/A record is 28X rwhp, it is yentzer's (from SSM) nitrous fox
blower/new cam soon
Old 08-26-2012, 11:42 PM   #9
1slosix's Avatar
ah i havent' been on MM in a while so i didn't know his final build was done. it's good to see that it came together good
Old 08-26-2012, 11:47 PM   #10
Region: Arkansas
not quite very good lol he cracked a head somehow (never heard what happened to cause it) so he's getting another set ported up to put on
blower/new cam soon
Old 08-27-2012, 12:45 AM   #11
xhgwx's Avatar
SMSS claims 300-400 engine power NA fully build hi-comp engine etc... Race crank... Etc...
But yes... Kyle is awesome to work with.
xhgwx is offline   Reply With Quote
Old 08-27-2012, 10:37 AM   #12
I have decided to go supercharger for these facts.
1.better mpg than n/a and close to. that of a turbo as long as u shift around 2g. I've personally rode in a gtp that had some engine work done when out of boost she got 30mpg. When in.... she kicked ***.
2.Less engine heat
3. Easier install
4. Less headaches for tuning
5. Less money since I have very little right now.
And lastly
6. And I have to agree... sc equals the original muscle thought. Turbo equals more of a ricer thought. Even though I wuld nvr bash either. Muscle boy at heart but "I can apreciate a good body regardless of make."
My question now if what sc wuld be best if I'm looking for around 600hp/580-620lb- torque?
Old 08-27-2012, 10:43 AM   #13
DaBluedude's Avatar
You would be way better off saving up and then selling your car and getting into a gt or cobra.
2003 Mach 1
Old 08-27-2012, 10:45 AM   #14
Stang.racr's Avatar
2.Less engine heat
3. Easier install
And lastly
You'd have to run a lot of boost 20#+ and have a fully built motor for 600 hp the gt's with the 4.6 only average 450 hp from a blower and bolt ons only and that's starting around 270rwhp. I don't frown on nos or look at it as a cheap alternative. I think it should be a final mod.
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 08-27-2012, 10:48 AM   #15
Region: Arkansas
A ysi blower lmao
600rwhp will be difficult with a supercharger, considering the amount of power they suck up, and to get a blower to support that power level it'll probably be cheaper to go turbo
As a side note a turbo can be cooled to very low IAT levels so you can mark that off the list of reasons
blower/new cam soon
Old 08-27-2012, 10:49 AM   #16
DaBluedude's Avatar
Trust me, if ir in a v6 mustang now, you are not ready for anything like 600 hp, nor do you have the money to complete such a build.
2003 Mach 1
Old 08-27-2012, 11:05 AM   #17
Region: Arkansas
Just because your in a gt doesn't mean you're ready for anything like 600rwhp either lol
You have to learn one way or another and thinking about it sure doesn't count
Also what car you drive doesn't mean how much money you have..
blower/new cam soon
Old 08-27-2012, 11:06 AM   #18
willrad00's Avatar
If your planning to go for big power definantly go turbo, boost can be adjusted with a couple of clicks of manual boost controller and You get way more power for the amount of money as compared to a supercharge.
Old 08-27-2012, 12:03 PM   #19
Mike SVOR's Avatar
375-400 rwhp makes an insane daily driver. You don't have a lot of spaces to even get on it for that long. 1st gear is useless and by the time you're out of 2nd, you're breaking the speed limit. LOL
1999 3.8 stang
1990 LX - supercharged 351w
1985 turbo 2.3 www.msvorinich.itgo.com
Mike SVOR is offline   Reply With Quote
Old 08-27-2012, 12:15 PM   #20
I'm not looking at having a car that just does the speed limit. Lol
I'm looking for a car that's competative.
Old 08-27-2012, 12:18 PM   #21
DaBluedude's Avatar
I don't own a gt. I have driven thousand hp vettes and awesome exotics. I didn't say I was able to fully exploit any of them. I just know that someone jumping from a stock v6 to a 600hp monster is going to end up in the hospital. Also if you're looking for cost effective power you probably don't have the money for it. Doing a proper build to 600 hp is a serious proposition.
2003 Mach 1
Old 08-27-2012, 12:20 PM   #22
The gts only make 200hp and idk yet if I wanna do my v6 or swap to a v8.
Old 08-27-2012, 12:33 PM   #23
Mike SVOR's Avatar
Competitive with WHAT? Don Garlits?
Don't mod your daily driver unless you have another vehicle. LOL
1999 3.8 stang
Old 08-27-2012, 12:43 PM   #24
Region: Arkansas
never said you were, just making a point...
as for cost effective even the big dogs like to spend money wisely, just because you have it doesn't mean you should throw it away, and no one trip out saying that a V6 is a waste of money the car it self is personal opinion
which gt would that be? i know the new edge gt's average 220-225rwhp stock (with somewhere around 260 tq)
blower/new cam soon
Old 08-27-2012, 12:47 PM   #25
1slosix's Avatar
Originally Posted by davidcseifert View Post
A ysi blower lmao
david i hate to say it but i have a friend running a liquid cooled ysi pushing over 1k to the wheels...he's been running it for a few years now. granted this is in a t-bird lol
Old 08-27-2012, 01:02 PM   #26
Region: Arkansas
uhh V8 t-bird i'm guessing? if it was a sixer everyone in our group would know about it lol
for that matter, the highest rwhp 3.8 based V6 motor is ~800rwhp in a T-bird incase anyone was wondering, with torque out the @$$
blower/new cam soon
Old 08-27-2012, 02:29 PM   #27
Competative with the street cars in the flint area. And I've seen quite a few sc and turboed cars get great gas milage. Also I wuldnt. E going straight to 600hp. I wuld be gradually upping the boost. I still have to do the internal work to the eingine.
Old 08-27-2012, 02:58 PM   #28
Mike SVOR's Avatar
So a nice T-70 unit, 8.5:1 pistons and some H-beam rods, and a Megasquirt II 3.57, and some 70# to 80# injectors, and a pair of in-tank fuel pumps or external, clutch, trans, rearend, laptop computer to program with, wide band O2 setup, intercooler, piping, custom headers, custom down-pipe, custom Y-pipe to duals, aftermarket fuel press regulator, intake filter setup, ignition coils(?), wires, plugs, dyno time, forgot engine balancing and while you're at it, might as well bore/hone cylinders and cut/polish crank journals.
Then enough money to cover all those credit card bills.
1999 3.8 stang
Old 08-27-2012, 04:29 PM   #29
Does this set-up aplly to sc?
Old 08-27-2012, 05:17 PM   #30
Mike SVOR's Avatar
Yep, minus the T-70 part.
Depends on what hp level you're looking for too.
I'd bet you could get 275-300 rwhp out of a standard bolt on supercharger without any more mods than an FMU and maybe a tuner. Or FMU and megasquirt and wideband O2.
Stock everything else should hold up to that level.
1999 3.8 stang
Old 08-27-2012, 05:38 PM   #31
I was told I culd use standard long tube headers because the sc wont affect the exhaust work.
Old 08-27-2012, 05:40 PM   #32
Mike SVOR's Avatar
Oh yea, sorry dude, my bad. Yea a SC can use stock headers and stock exhaust until you buy new.
1999 3.8 stang
Old 08-27-2012, 05:50 PM   #33
Also a mechanic told me that my trans can support up to 400hp and that my rear is strong enough cuz its in the 8:8 family. Is that true?
Old 08-27-2012, 08:21 PM   #34
DaBluedude's Avatar
It might work for awhile but the 7.5 rear wont work and you'll want to get a lsd anyways.
2003 Mach 1
Old 08-27-2012, 10:19 PM   #35
Region: Arkansas
you'll need better injectors and pump to support that power level of 300rwhp+, my 242rwhp strains the 21's hard and it's just an N/A motor, boosted motors need bigger injectors than an N/A motor would
the trans can take more than that, but your torque converter will not like you at all, a good stall and a cooler would be recommended for a lot of power, also a shift kit would prolong it's life
and unless you did the swap and the mechanic saw it on the car, he doesn't know much about the cars it seems lol only the gt's had an 8.8, it's a direct swap in with the correct year range
blower/new cam soon
09:47 PM
