Operation "Boost" is a go - Mustang Evolution
Old 08-24-2012, 08:19 PM   #1
Welp this last weekend I found a m90 off a 91 supercoupe pretty cheap for my 98 sixxer. But I think I'm going to try something different. I really dont want to deal with all the accessories being moved, ac lines, ect... I believe I can make a braket to lift and then extend the blower forward to my orginal accessory belt. Has anyone done this? I do have a little advantage by having a 3 in. cobra R hood and I think thats all I need.
Robey is offline   Reply With Quote
Old 08-25-2012, 07:32 AM   #2
rinfield2004's Avatar
Re: Operation "Boost" is a go
3in cobra R hood should do. don't see any reason why it wouldn't. from what I understand, it should be a straight swap considering theyre both single ports.
rinfield2004 is offline   Reply With Quote
Old 08-25-2012, 03:36 PM   #3
It is a straight swap except I dont want the two belt set up. I'll keep posting as I make progress. Kinda keeps me sane to write it out as I go. Tomorrow I'm going to go pick up a front mount intercooler for it.
Old 08-26-2012, 12:13 PM   #4
willrad00's Avatar
Sounds like a sweet project, make sure we see pics as you go!
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 08-26-2012, 02:17 PM   #5
Dgerow12's Avatar
Absolutely. And where I am M90's are a dime a dozen so it would be cool to have a way to set one up on my v6 as well. Definitely keep us posted
Dgerow12 is offline   Reply With Quote
Old 08-26-2012, 06:55 PM   #6
Will do. Here's the car that is receiving the transplant and her new parts!
ID:	65737   Click image for larger version
Old 08-26-2012, 11:44 PM   #7
davidcseifert's Avatar
Region: Arkansas
you do know you need the supercoupe heads to bolt on the supercoupe lower intake/blower right? the mustangs single port heads are missing a bolt hole for the lower intake to attach to it....
this happens to a lot of people lol
blower/new cam soon
Old 08-27-2012, 07:32 AM   #8
Actually I can use my heads. It will just take a little more work. You can actually drill and tap those missing two bolt holes into the head. Here is a form post about it.Results With 96-98 Mustang Heads - Super Coupe Club of America Forums
Old 08-27-2012, 07:58 AM   #9
Region: Arkansas
Good luck
blower/new cam soon
Old 08-27-2012, 09:33 AM   #10
94sccoupe's Avatar
Region: West Virgina
Good luck. R u able to get the entire engine, u goin to wish u had those forged internals.
94sccoupe is offline   Reply With Quote
Old 08-27-2012, 10:26 AM   #11
most of the entire engine is required when using a supercoupe blower, its not worth the end results enter for the power levels some make a kit for adapting the M112 from an 03/04 cobra onto a single/dual port 3.8/3.9L v6. The end result is a non cooled 8psi - 10psi vehicle that puts on rather good number overall but the non cooled part kills it no way to really run a cooler of any type other than meth injection
even with an M112 its a bad blower (root vs twin screw) so its VERY hot. Look into a vortech/procharger instead.
Old 08-27-2012, 11:21 AM   #12
Region: Arkansas
If you can try to get in touch with this S_Mazza guy on sccoa to see if the fix held up, I saw one post about how it held up through tuning but that was a year ago with no more reports in that thread, I would definitely find out before I started drilling in my own heads
blower/new cam soon
Old 08-27-2012, 11:28 AM   #13
94sccoupe's Avatar
^ yeah and it sounds like a real pain in the arse.
Old 08-27-2012, 01:10 PM   #14
l'll look more into it but I can't see why it wouldnt hold up. I'm not looking for much power at all. Just a project to do. I understand it's not going to be easy. For the cooling part the front mount should really help out compared to the stock intercooler the supercoupe came with and I dont plan on running full boost. I will try to be around 8-10lb. For the fuel system I have a svt focus pump with 30lb injectors. I might later plan on getting the forged block if I feel I really need it, but people don't give our 3.8 enough credit. It should hold on a good tune.
Old 08-27-2012, 08:29 PM   #15
I did contact him and he said the motor runs perfect since that fix.
Old 08-27-2012, 10:21 PM   #16
Region: Arkansas
hope it holds for you man, good luck
blower/new cam soon
01:15 AM
