Bad Gas - Mustang Evolution
Old 08-27-2012, 04:42 AM   #1
94sccoupe's Avatar
Region: West Virgina
Bad Gas
Whats the best way to drain the gas tank. I dont want to drop the tank if i can keep from it . Tried to just siphon it out but there must b a block in the tank to keep someone from stealin the gas.
94sccoupe is offline   Reply With Quote
Old 08-27-2012, 04:51 AM   #2
Re: Bad Gas
yes there is a ball like block at the bottom of the filler,,sometimes you can use a small hard plastic line,,about 1/4 in diameter,,might get around the block,,and get to the tank
mymustang is offline   Reply With Quote
Old 08-27-2012, 11:44 AM   #3
94sccoupe's Avatar
Really? Noone else has ne ideas.
---------- Post added at 01:44 PM ---------- Previous post was at 01:42 PM ----------
Yeah i went to the hardware store and bought a smaller stiffer tube but no luck. Thanks though
Old 08-27-2012, 12:10 PM   #4
Mike SVOR's Avatar
Re: Bad Gas
You can disconnect your fuel line using the proper line disconnect tool then manually trigger your fuel pump using jumper wires on the relay.
You can disconnect your fuel lines at the fuel filter and siphon it out that way. I think you'd still need the fuel pump on though.
Whats wrong with the gas?
1999 3.8 stang
1990 LX - supercharged 351w
1985 turbo 2.3 www.msvorinich.itgo.com
Mike SVOR is offline   Reply With Quote
Old 08-27-2012, 12:29 PM   #5
94sccoupe's Avatar
Turning the key on wouldnt start the fuel pump?
---------- Post added at 02:18 PM ---------- Previous post was at 02:16 PM ----------
Thought about doin that but didnt have the proper tool. Its the same type u use to disconnect the a/c isnt it
---------- Post added at 02:29 PM ---------- Previous post was at 02:18 PM ----------
Im not sure if the gas is the problem, but my car is tuned for 92octane and without thinking and bn told by someone that was good gas, i put 90octane , i cant remember if it contained ethanol.or it didnt but it was a special type.of fuel. The car ran fine until i put that n the tank. Coincidence or not idk. Now it wont hardly idle and has black smoke out the tailpipe
Old 08-27-2012, 12:45 PM   #6
1slosix's Avatar
Re: Bad Gas
well you're running rich big time if it's black smoking...the gas might be part of it, but i'd consider other things as well
Old 08-27-2012, 12:56 PM   #7
davidcseifert's Avatar
Region: Arkansas
Re: Bad Gas
well in normal cases a tune with the timing retarded would stop and problems from using a lower octane gas, but i know the supercoupes are suppose to run on 91 or better from the factory so yeah drain it..
the trick with the key only works shortly to trigger the pump to prime the rail until the car is started, but with the regulator constantly reading no pressure it might continue pumping the fuel until it's empty, not sure on that though, worth a shot if not do like mike said and trick it with an alternate power source
blower/new cam soon
Old 08-27-2012, 01:30 PM   #8
94sccoupe's Avatar
Such as... Not sure how to do that.
---------- Post added at 03:30 PM ---------- Previous post was at 03:27 PM ----------
Yeah so far ive changed the camshaft sensor. Made no difference. Do u have suggestions on what i should do next.
Old 08-27-2012, 01:50 PM   #9
Mike SVOR's Avatar
Re: Bad Gas
Drop the tank. Its like 3 bolts.
1999 3.8 stang
Old 08-27-2012, 02:16 PM   #10
94sccoupe's Avatar
Thats lookin like my only option. The fan relay is part of the ccrm and looks like trouble if i go missing with that. Think i can loosen straps on the tank enuff so i can get the filler neck out and access the tank that way. Man i hope thats the problem. Ive really had a time with this car.
Old 08-27-2012, 03:15 PM   #11
Mike SVOR's Avatar
Re: Bad Gas
There's another way.
Remove the schrader valve on the fuel rail, hook a hose to it and direct it to a gas jug, then jumper the power wire coming from your inertia switch in the rear of the car to the fuel pump. Just add 12 volts to the proper wire and it'll come on and drain your tank.
1999 3.8 stang
01:58 AM
