new throttle body? - Mustang Evolution
Old 08-30-2012, 10:06 AM   #1
Horseplay's Avatar
new throttle body?
what are the signs of a bad throttle body? is there a way to clean my stock one ? or is best to buy an aftetmarket one?
Low2v
Old 08-30-2012, 11:08 AM   #2
Jgill1992's Avatar
Just get throttle body cleaner from your local parts store. You CAN clean the TB on the car but it's easier to get a good clean with it off. Just blast it with throttle body cleaner and wipe it down until its shiny all over if it was dirty enough to cause problems you should notice a pretty huge difference in idle and smoother RPM's
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 08-30-2012, 11:40 AM   #3
Horseplay's Avatar
awesome thanks for the help. is a pain to remove the throttle body?
Low2v
Old 08-30-2012, 11:53 AM   #4
Jgill1992's Avatar
It's very easy in most cases. Usually just 4 bolts and its off. The toughest one I've ever done was a 96 Oldsmobile ... And it took like 2 hours.
If it looks like its going to be a HUGE pain you can clean it wile it's on the car but make sure you get behind everything really good.
Old 08-31-2012, 09:04 AM   #5
Dgerow12's Avatar
Get a new gasket before you try to remove!!! I had to whack mine off because it was stuck on there
Dgerow12 is offline   Reply With Quote
Old 08-31-2012, 11:50 AM   #6
Re: new throttle body?
+1 you will for sure need a rubber mallet mine and three friends were crazy stuck and make sure you prep the manifold a t.b surfaces b4 u put it all back together or your new gasket will leak
l2plagears is offline   Reply With Quote
Old 08-31-2012, 04:38 PM   #7
jdavis96gt's Avatar
Region: West Virgina
Will the TB cleaner cause problems if it goes down in the motor? If you don't take it off and try to clean it.
Is it possible to get it clean without taking it off?
Sorry for the hijack, I was curious.
08:16 PM
