Code p1000 - Mustang Evolution
Old 08-31-2012, 01:05 AM   #1
Code p1000
I've been having problems getting my 00 running again - she won't crank but anyways I checked to see if any codes are poppin and I got p1000... Would this cause the car not to crank?
Black_Sunshine is offline   Reply With Quote
Old 08-31-2012, 08:29 AM   #2
maldog's Avatar
Region: Nevada
Re: Code p1000
Hey BS,
This is FYI that you should know about the P1000 you're getting.
P1000 has no affect on engine control or performance...
When you turn your key on do your gauges flip and go to max?
This means that fuse #21 in the Central Junction Box (under the dash) is blown, or that there is a wiring problem preventing the PCM from receiving the constant +12V it needs to maintain the Keep Alive Memory (KAM). Without this power the PCM will forget everything it has learned when you shut the key off.
This fuse also provides a constant +12V to the instrument cluster. If this constant power is not supplied the instruments will sweep when the key is turned on.
This issue may not have any profound affect on the symptoms you describe, however without the adaptive learning being active it will be difficult to diagnosis. I would suggest you check fuse #21.
Good luck.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-31-2012, 09:26 AM   #3
Re: Code p1000
I'll check it out later on today - I don't think the gauges sweep? but I've checked all the fuses and they all seem solid i'll give them a once over again.
also would I get this code to pop because I'm taking the battery out when I try to figure out why this car isn't cranking?
Old 08-31-2012, 04:49 PM   #4
maldog's Avatar
Region: Nevada
Re: Code p1000
Yes you can get the code from doing that because it's a re learning process that the PCM flags because it cannot read the logging parameters of the engine and thinks something is wrong.
Also, have you checked your battery? Is it putting out enough volts and holding a charge?
Good luck.
Old 08-31-2012, 09:32 PM   #5
Re: Code p1000
checked the voltage at the bat - 12 the cables - 12 - Still haven't checked the starter... also where would i find the starter silanoid
Old 08-31-2012, 10:26 PM   #6
maldog's Avatar
Region: Nevada
Re: Code p1000
Ok I'm trying to remember on the 2000 model the starter solenoid is located on the drivers side firewall area if I'm not mistaken?
If that is your problem you can also use a screwdriver and jump the terminals to see if it turns over.
Old 08-31-2012, 10:33 PM   #7
Re: Code p1000
If evrything is good,,fuses and no problems,,has the battery been disconnected,,because you can have this code until your computer goes through the drive cycle,,and all the obd 2 monitors have been set,,The evap system takes the longest to set..
mymustang is offline   Reply With Quote
09:06 AM
