Turboing a 2000 v6 - Mustang Evolution
Old 03-20-2008, 01:45 AM   #1
Turboing a 2000 v6
i am about to start turboing my 3.8 with a mid size garrett turbo. i need to know what injectors, maf, and throttlebody to use, with a low buget, i also need to know what to do with the exsisting four o2 sensors, if anyone can help that would be great.
garybird440 is offline   Reply With Quote
Old 03-20-2008, 05:22 AM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Turboing a 2000 v6
you may want to post up some more specs on the the turbo.... as well as PSI that you'll run it at. That way people that know more than I do can help out. You could always go totally safe on the throttle body and just get a 75 mm. I'm not sure on injectors.
Old 03-20-2008, 07:59 AM   #3
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
I'd go with the lightning 90mm maf so you don't grow out of it. as already said we would have to know how much hp you're planning on so you can decide on the best injectors.
Before I wrecked my six I was getting all my turbo parts together and I was just planning on keeping the o2 sensors in their stock position. I've seen people have one on the cold side and then others argue that its the wrong way to do it so I'm not sure about that. depends on how you set up your piping.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 03-20-2008, 09:47 AM   #4
rydog's Avatar
Send a message via MSN to rydog
Both o2 sensors need to remain between the heads and the turbo on the hotside
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 03-25-2008, 11:02 AM   #5
I carry a 42lb pencil injector from the 03/04 cobra that is a drop in replacement and is good for at least 400rwhp on a turbo car. The easiest fuel pump solution is to drop in the 310lph that I also carry. I would run an 05+ style maf in blow-through, I have all the sensors, adapter harnesses, and flanges or housings on my site to make it work well. The 90MM Lightning maf would not work very well in blowthrough and would peg early.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 03-27-2008, 01:41 AM   #6
thanks ill check your site out
2000 v6. what should I do first? BMustang1 Pre-2005 V6 Mustang 23 03-30-2009 04:53 PM
My new 2000 V6 Ibanezplayer272 Pictures and Videos 21 02-26-2006 10:26 AM
2000 v6 starboarder2004 Pre-2005 V6 Mustang 8 12-07-2005 02:12 PM
AND we have 2000!!! Zim The Bar 23 03-29-2005 02:25 PM
rebuilding engine and twin turboing tek55 Pre-2005 V6 Mustang 20 03-26-2004 01:38 PM
10:09 AM
