Confused Gauges - Mustang Evolution
Old 08-31-2012, 10:22 PM   #1
Confused Gauges
Hey there guys... I have a 1994 Ford Mustang V6 that has the gauge cluster lights go off a lot and then come on sporadically. I am not sure what is going on. This cannot be the bulbs, so I am not sure what it is. The gauge cluster will be off at night and then they come on all of a sudden.
Any ideas would be greatly appreciated...
devanslive is offline   Reply With Quote
Old 08-31-2012, 10:31 PM   #2
maldog's Avatar
Region: Nevada
Re: Confused Gauges
It sounds like your gauge rheostat is going bad. Time to replace it
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-31-2012, 10:36 PM   #3
Re: Confused Gauges
Okay... That is new to me. What is a rheostat and is it an easy fix?
Old 08-31-2012, 10:51 PM   #4
maldog's Avatar
Region: Nevada
Re: Confused Gauges
The rheostat is what makes your cluster gauge lights brighten and dim by moving the small wheel or it's integrated on your headlight pull switch. I can't remember on the 94 model? It's a ceramic part that has a spring on it and usually the springs get corroded and the lights will come on and off whenever they want.
The problem you might have is finding a new one at a auto parts store due to the age. You might have to try and find a good one at a pick a part. They are not hard to replace.
This is a common problem with the old style lighting.
Old 09-01-2012, 04:04 AM   #5
Okay. Thanks for that bit of insight.
Old 09-01-2012, 05:25 AM   #6
9tee7pony's Avatar
Or you could get a reverse glow gauge insert. You're going to have to take that part of the dash apart either way.
What a rheostat actually is, is a variable resistor. In case you don't know what a resistor does, it impedes the voltage in an electrical circuit in order to make the voltage drop to what is needed for that application. The rheostats are typically used in dimmer switches and volume knobs. Not so much today though since most of it is controlled by a computer.
You might find luck finding a new one on latemodelrestoration.com or something like that.
9tee7pony is offline   Reply With Quote
Old 09-01-2012, 11:39 AM   #7
Would a reverse glow insert remove the need to replace that part?
Old 09-01-2012, 01:17 PM   #8
9tee7pony's Avatar
Yes it does because it comes with its own and then the one that you use now controls the needle, odo, clock, radio and ac control brightness. The only problem with the reverse glow gauges is that they tend to make the needles get stuck.
Old 09-01-2012, 02:03 PM   #9
So it would be less expensive to go with that option. From what I have seen they are not terribly hard to install.
Old 09-01-2012, 04:55 PM   #10
9tee7pony's Avatar
It was like $45 and you must put the ground wire on a screw on the fuse box under the dash. Took me awhile to figure that out.
Old 09-01-2012, 05:09 PM   #11
Re: Confused Gauges
Oh okay... On the instructions I read it said to put the ground on the chassis. So it goes on the fuse box...? Cool, thank you!!!
Old 09-01-2012, 07:13 PM   #12
9tee7pony's Avatar
I didnt have anything to drill into the chassis and I found out that the fuse box is the easiest way
Old 09-09-2012, 04:10 PM   #13
Isn't the fuse box plastic? The wire does not look like it will reach under the dash. Also, where do the three prongs go? It is not listed anywhere in the directions.
08:33 AM
