a little extra horsepower - Mustang Evolution
Old 09-01-2012, 05:11 PM   #1
Mustang19's Avatar
So here is my idea I have a 03 auto. I already have a tuner headers and a kn filter. My ideas are 4.10 and an upgraded diff. Next idea was a bbk throttle body and a cold air intake but I have heard that the throttle body wasnt worth it and if the kn filter works just as well as a cold air? What do u guys think and do u have any other suggestions
Mustang19 is offline   Reply With Quote
Old 09-01-2012, 06:06 PM   #2
alrefire's Avatar
Re: a little extra horsepower
well, it depends on the Cold Air intake, if the intake requires a tune, it usually has wider piping than the stock airbox, so you will gain more whp.
the others are kinda iffy.
the throttle body won't make much of a difference, but is good for 10-15 whp, if tuned. I'm not sure your car comes with a dif, but if i were you i would look into upgrading into an 8.8 rear end.
and if you're gonna get it dyno tuned, i would recommend meth injeciton, easy 50+ whp.
Old 09-01-2012, 07:10 PM   #3
Mustang19's Avatar
I was looking at the windstar kit but it says it has been discountinued? Does anyone know were I could still get one and if their worth it? My goals are to beat a 3800 camaro
Old 09-01-2012, 07:25 PM   #4
alrefire's Avatar
I don't kno about ur model year
But am has one for mine
I would definitely check am for a kit
And if they don't have one u can probably still use the one for the 05 GT, just tweak it a little
Old 09-01-2012, 08:47 PM   #5
1slosix's Avatar
you should already be able to run with any 90's model v6 camaros...and even the first run of newer v6 camaros before chevy started working them up a bit
Old 09-01-2012, 08:50 PM   #6
Mustang19's Avatar
Yeah I'm talking about series 2 3800 with 220 HP I think
Old 09-01-2012, 08:51 PM   #7
1slosix's Avatar
thats only a 20-30 hp difference and they weigh a fair amount more then you...plus their gearing sucks.
Old 09-01-2012, 09:06 PM   #8
Mustang19's Avatar
So are u saying I should be good after the 4.10 or without them?
Old 09-01-2012, 09:15 PM   #9
1slosix's Avatar
stock for stock
Old 09-01-2012, 09:35 PM   #10
McNassty's Avatar
Meth injection?
---------- Post added at 03:33 AM ---------- Previous post was at 03:29 AM ----------
That's for S/C or T/C
---------- Post added at 03:35 AM ---------- Previous post was at 03:33 AM ----------
And a aftermarket throttle body will be good for 2-4 HP maybe 6-8 tuned
McNassty is offline   Reply With Quote
Old 09-02-2012, 12:57 AM   #11
McNassty's Avatar
Oh and I'm sure there are methanol N/A cars running around but I'm sure they are running high (really high, since it takes high compression) compression, and since it takes a lot to make high compression in a V-6, I'm pretty sure our bolt on modded OP doesn't come into this category. Stick to wrestling since modding isn't your thing yet
Old 09-02-2012, 06:59 AM   #12
alrefire's Avatar
Fine then :p
Old 09-02-2012, 08:40 AM   #13
Mustang19's Avatar
In the video was the mustang an auto? Bc I raced a 02 ss impala with the 3800 and got smoked .. it wasn't even close lol
---------- Post added at 08:40 AM ---------- Previous post was at 08:37 AM ----------
I take that back it wasn't technically an ss it was the ls with the 3800 but he told everyone it was an ss lol
Old 09-02-2012, 08:52 AM   #14
Stang.racr's Avatar
Meth can be run on a n/a engine but corrosion is a bad issue. Gears should be your main priority
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 09-02-2012, 09:04 AM   #15
Mustang19's Avatar
Yeah right now gears and a LSD are my main ... But I'm just looking into what elese after that. If I do add the throttle body will the stock intake allow me to see HP gains with a tuner or will that need to be larger as well?
Old 09-02-2012, 10:38 AM   #16
Fourloko530's Avatar
Hmm
Fourloko530 is offline   Reply With Quote
Old 09-02-2012, 10:53 AM   #17
Dgerow12's Avatar
Stock intake will need to be larger but a throttle body won't do much unless the rest of the intake system is ported for it.( manifolds, and heads) and also as you upgrade intake...when you car inhales better it also needs to exhale better....so look into a good dual exhaust system as well.
Dgerow12 is offline   Reply With Quote
Old 09-02-2012, 11:42 AM   #18
Mustang19's Avatar
Alright I will weight to do the throttle body till I do the cam and heads
Old 09-02-2012, 04:31 PM   #19
austinknoll's Avatar
How do you port it? Who do I have to take it to to get them to port my intake? How much power increase?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 09-02-2012, 04:54 PM   #20
Mustang19's Avatar
Also would a tune be requried when porting or just once the new tb has been added?
Old 09-02-2012, 11:11 PM   #21
Dgerow12's Avatar
If the intake only is ported then I would say no a tune is not required but if you port the heads and intake and put a throttle body on it I would suggest a tune to boost your gains. After all the porting w/o tune you could get about 10 hp but if you get a good tune for all that you could be looking at about 15-20 rwhp. But that's if everything is done PROPERLY.
Old 09-02-2012, 11:13 PM   #22
What just have it ported by a performance dude
Old 09-03-2012, 01:14 AM   #23
I don't know Any performance shops in sandiego. Wha is the downside to porting the intake?
65 Mustang coupe
Old 09-03-2012, 09:12 AM   #24
Mustang19's Avatar
And how much are we looming at in cost if we take it off and take it to the shop?
Old 09-03-2012, 09:44 AM   #25
Dgerow12's Avatar
They usually charge anywhere from 200 to 450 I've heard of. And the downside of doing it yourself is taking to much off or messing up the taper and actually hurting your performance
Old 09-03-2012, 10:48 AM   #26
Mustang19's Avatar
Yeah defintly not doing it my self lol if the intake is ported what is a recommend tb size?
---------- Post added at 10:48 AM ---------- Previous post was at 10:48 AM ----------
Or will the stock work
Old 09-03-2012, 01:53 PM   #27
Dgerow12's Avatar
For a single port it's usually a 56mm for a new edge it's usually a 65mm tb
Old 09-03-2012, 02:16 PM   #28
Mustang19's Avatar
I think I have a split port. I have an 03
Old 09-03-2012, 02:23 PM   #29
1slosix's Avatar
yes it's a split port
Old 09-03-2012, 02:33 PM   #30
Random thought, what is the biggest reason why the 3.8 only has 190 HP? I realize it wasn't built for performance and was a van engine. I get that. But what is holding it back?
65 Mustang coupe
Old 09-03-2012, 02:40 PM   #31
1slosix's Avatar
the parts used to build it and how it was built with certain parts
Old 09-03-2012, 02:52 PM   #32
Mustang19's Avatar
Another random question lol instead of porting the intake and doing work to the motor would it be more benificial to swap a 4.2 in? I heard doing a 4.6 isnt worth it but what kinda gains can be seen with a 4.2 and how hard would the swap be?
Old 09-03-2012, 03:00 PM   #33
Horseplay's Avatar
i would go with a v8 swap.. thats jusy my 2 cents
Low2v
11:40 AM
