2000 V6 to 1979 351w swap - Mustang Evolution
Old 09-01-2012, 06:51 PM   #1
351
Thumbs up 2000 V6 to 1979 351w swap
I am swapping my V6 with a 351w. I have a 2000 V6 SN95 body type with the T5 transmission.
1. will I need to swap the K member to the V8 SN95 or foxbody K member? or will the one I have work?
2. which flywheel will I need to use? the one that was on the 351 or from the 3.8?
I am getting varying answers from searching around so I figured I would go right to the source. I appreciate any clarifications on these issues, and thanks in advance.
351 is offline   Reply With Quote
Old 09-01-2012, 07:11 PM   #2
93slowstang's Avatar
If I remember correctly the v6 k member will work , you will definitely have to use the 351 flywheel though.
Old 09-01-2012, 07:35 PM   #3
351
I have searched around for about a week, thanks! Just went and got the GT40p intake, heads and EFI.
Old 09-01-2012, 07:41 PM   #4
deadsp0t's Avatar
Think you need a K-member if your 6 is 99-04.
That's unimpressive
Old 09-01-2012, 07:45 PM   #5
Lorraine's driver
ab_mach1's Avatar
Nice avatar deadsp0t. A assume that's your little one?
---------- Post added at 09:45 PM ---------- Previous post was at 09:44 PM ----------
This will be a cool swap. You should start a swap thread once you get started.
Instagram: @ab_mach1
Old 09-01-2012, 08:01 PM   #6
351
Re: 2000 V6 to 1979 351w swap
I've got the pics and I will be uploading them soon. I want to stick with this thread so that everyone will know what worked and what didn't. I appreciate all the input.
Old 09-01-2012, 08:05 PM   #7
Lorraine's driver
ab_mach1's Avatar
Ha! I re-read the title and magically my brain put the two together. This is the perfect title Lol!
Old 09-01-2012, 08:34 PM   #8
351
thanks, this is a lot of info and digging to do for this swap to this year.
---------- Post added at 09:34 PM ---------- Previous post was at 09:09 PM ----------
nice engine pic.
Old 09-01-2012, 08:39 PM   #9
deadsp0t's Avatar
Yup yup'
That's unimpressive
Old 09-01-2012, 08:48 PM   #10
Lorraine's driver
ab_mach1's Avatar
Yup yup'
Very cool
Old 09-01-2012, 09:05 PM   #11
351
Nice, I really like the sound of flowmaster exhaust. I've heard that this swap will get around 400 are the flywheel. Do you know if the bellhousing from the 3.8 will mount to the 351?
---------- Post added at 10:05 PM ---------- Previous post was at 10:02 PM ----------
I seen where there might be an issue with the length of the input shaft.
Old 09-02-2012, 04:33 PM   #12
deadsp0t's Avatar
Only an issue if you use a T5 from a 93 and older.
Could also be an issue using a V6 T5, which I would strongly discourage anyway as it won't last long at all. There are DS spacers for using other transmissions. You'd be wise to contact D&D performance.
That's unimpressive
Old 09-02-2012, 04:40 PM   #13
351
I have been looking through Delk performance, I'll take a look at D&D. Thanks.
01:12 PM
