Popping when I drive? - Mustang Evolution
Old 09-03-2012, 09:34 AM   #1
Hey, guys!
I have a problem with my car making popping sounds as I drive. It's not when I turn, so I don't think it's the ball joints? And the popping goes as fast as I drive.
If it helps any, I've had a little alignment problem for a while, ended up changing the driver side strut, probably made it worse.
The sound sounds like it's coming from the center of the axle, though?
Any ideas?
Fox Fan is offline   Reply With Quote
Old 09-03-2012, 10:13 AM   #2
1slosix's Avatar
Re: Popping when I drive?
u joint maybe
Old 09-03-2012, 10:18 AM   #3
Forum Car Trader
90GTNovi2000's Avatar
Check your driveshaft bolts. Also transmission mount, control arms and sway bar.
90GTNovi2000 is offline   Reply With Quote
Old 09-03-2012, 12:05 PM   #4
Guys, I figured it out. See, my friend kinda loosened both my passenger wheel and driver wheel lugs... we didn't tighten the passenger ones back. So I drove all the way to Knoxville and back with 3 lugs. Dangerous.
Old 09-03-2012, 12:55 PM   #5
nhcowboy's Avatar
Uhhhhhhh.... <loss for words>
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 09-03-2012, 02:12 PM   #6
1slosix's Avatar
and why did he do that...also where in TN are you located since you drove all the way to Knoxille...are you from middle TN?
03:07 AM
