turbo size?? - Mustang Evolution
Old 09-03-2012, 11:46 PM   #1
turbo size??
What turbo size will I need to make 30psi? And how far can u turn a turbo down? (I.e. can a 30psi turbo run only 4psi?)
morthis32 is offline   Reply With Quote
Old 09-04-2012, 04:26 AM   #2
davidcseifert's Avatar
Region: Arkansas
Re: turbo size??
get this and be done
http://www.precisionturbo.net/Street...-CEA%C2%AE/329
blower/new cam soon
Old 09-04-2012, 11:13 AM   #3
Originally Posted by davidcseifert
What psi is that turbo?
Old 09-04-2012, 11:22 AM   #4
Forum Car Trader
90GTNovi2000's Avatar
Turbos are measured in millimeters.. Like a 76mm.. 30 psi really on what kinda car..
90GTNovi2000 is offline   Reply With Quote
Old 09-04-2012, 11:27 AM   #5
2300turboford's Avatar
Yes get a waste gate and boost controler and run a 4 lbs waste gate spring and 30lbs through the boost controler and a hx-35 loves 30 lbs
Old 09-04-2012, 11:45 AM   #6
So what theory do u use for how much psi to how many mm a turbo can do?
---------- Post added at 01:45 PM ---------- Previous post was at 01:45 PM ----------
Please explain again. I'm not understanding your wording.
Old 09-04-2012, 12:06 PM   #7
Re: turbo size??
This build won't ever happen, stop dreaming, be more realistic.
You probably don't have 30 grand to throw at your v6 mustang.
30psi and then down to 4? Are you stuck on PSI numbers, it doesn't mean anything you should start going by HORSEPOWER numbers. Do some research first, nobody goes into a 30k build blind.
ChrisTorres08 is offline   Reply With Quote
Old 09-04-2012, 12:17 PM   #8
Amen
Old 09-04-2012, 12:29 PM   #9
Forum Car Trader
What's an hx-35 I don't know much about the smaller foxes
Old 09-04-2012, 02:35 PM   #10
1. I'm planning the build. Not going blind. Haven't started buying anything yet. Just planning.
2.It'll be prolly a 5yr project.
3. I asked people what size turbo they have and they tell me what psi they r pushing. Not my fault that's all Im told.
4. I'm asking so I can learn. If ik I wuldnt have asked. Keep the posts positive.
5. I'm dropping a 1995 supercoupe engine in and starting from that base.
Old 09-04-2012, 03:36 PM   #11
Re: turbo size??
Lol, 5 year projects never make it anywhere this is the internet, the land of dreams.
Maybe you should stop ASKING, and start RESEARCHING online everything you want to know can be found on google.
Why would you put a 95 supercoupe engine in the car? Its going to need a 100% custom built motor (forged pistons, rods, arp hardware, race bearings, etc, etc) [10k ish motor]
You want 600hp? Simple grab a precision 6766 Or a borg warner s366!
Now you know 30% of your setup.
Then you will need fuel system (cobra tank, dual pumps, braided fuel lines, injectors)
a turbo kit itself.
8.8 rear end with 31 spline true trac + axles
built transmission
tires to keep the power to the ground
yeah that is about 90%
some tuning software and a tune(dyno)
Money
Old 09-04-2012, 06:19 PM   #12
a turbo kit itself.
built transmission
Money
K.
Old 09-04-2012, 08:22 PM   #13
Stock turbo on a 5.9 cummins
---------- Post added at 10:22 PM ---------- Previous post was at 10:21 PM ----------
56mm i think
Old 09-04-2012, 09:11 PM   #14
Whiteboss302's Avatar
The hx35 is a 54/58/12. hx40 is a 60/58/12 The hx35 with the silencer ring taken out will see about 32 psi with a water meth injection. I just got rid of my cummins to get the boss. Handles way better than the truck. But it's fun as crap to launch in 4wd and take a 7000 point truck down the track in 8.12 in an 1/8. Hope to get the boss to the track soon and see what it's got
Whiteboss302 is offline   Reply With Quote
Old 09-04-2012, 09:15 PM   #15
Forum Car Trader
No joke around hear I've seen them run low 7's and then pull the trailer home with a 5 second car
Old 09-04-2012, 09:32 PM   #16
Yea i wanted to build my truck to run in the 10s in a 1/4 but just cost way to much to build a diesel to do that. Guy that help me build my trans has a fox body tube car with a cummins in it runs mid to high 5's thing has 3 turbos though two 75mm and one 65mm running 110 psi just got it in though so it isn't hooking up like it should
Old 09-04-2012, 09:38 PM   #17
a turbo kit itself.
built transmission
Money
1. I'm driving the car and doing mods when I get the money hence y it will take so long.
2. What part of positive do people in this forumn not get?? All negativity does is tear, not build.
3. When I was asking what size it is and the psi its cuz people tell me that 20psi doubles the hp u make w/o the turbo.
4. Im currently helping my fiance pay for her college so i have to save for parts for my car. And right now im asking people who i thought were knowledgeable in the turbo subject. Trying to learn. If ur not willing to help/tech then. AGAIN dont post. So ya. Positive help please or just stop posting. That'll be great.
---------- Post added at 11:38 PM ---------- Previous post was at 11:36 PM ----------
That's crazy! Hey if u like that look up 1995 diesel mustang. A guy dropped a cummings in a mustang. No joke.
Old 09-04-2012, 09:45 PM   #18
If its rich Buckley that's the guy in talking about I was thinking it was a fox body for some reason he had that motor in a 1500 regular cab dodge and he sold that truck and built the tube car. He knows his stuff when it comes so a cummins.
Old 09-04-2012, 09:50 PM   #19
The engines red and its only tubing around the frond end. Windshield and forward. From the door hinges back is flat black.
Old 09-04-2012, 10:09 PM   #20
xhgwx's Avatar
Okay OP:
Go get a 4.2L truck engine.
Break it down to bare block
Send block in for an acid dip and good cleaning.
Order 4.3L long rod Stroker kit from super six motor sports. Forged dished top pistons shoot for a 8.5-9.0:1 compression ratio. Punch the block out for the bigger pistons to fit. May need sleeves(most likely will) get their custom race prepped crank. Get a custom boost cam ground from them, stage 3 heads with ported valves, upper and lower fully polished and ported, or a Windstar intake. Upgrade valve springs, make sure everything is forged an bullet proof. New motor mounts. Drop the tranny, send it in for a rebuild, shift kit. Will also need a trans cooler. Buy and 8.8 Rear end, put in a auburn t-Lok with 3.55 gears. Will need 31 spline axels.
Custom Drive shaft(aluminum or steel) which ever it needs to be strong as hell.
Twin turbo from TMA or a big single turbo as stated above
Now you have most of the major **** done. Support ****
Custom fuel rails!
Huge injectors probably near 70-80lbs
Cobra pump
Full new suspension
Full new brake system
Exhaust(done with the turbo set up)
New wheels and tires to fit more meat
Then you need to repair the exterior.
Body panels and trims(includes parts like goods and bumpers)
Paint
Then the interior
New carpets
New covered seats
Headliner
Sir you aren't just looking at a 30k build.
The long rod Stroker build with turbos times 1.5 for install is near 15-18k
With the money you will dump into this car in let's say 5 years.
You could have half a down payment on the newest and best Shelby(or cobra what ever they come out with then, like the Shelby).
In my honest opinion.
Call a reputable performance shop.
Do a Coyote or termi engine swap(8-10k)
And you'd have a car that allows more mods and is better acceptable to mods. And for less.
My .02
::End::
xhgwx is offline   Reply With Quote
Old 09-04-2012, 11:10 PM   #21
Originally Posted by xhgwx
Okay OP:
Custom fuel rails!
Cobra pump
Full new suspension
Paint
Then the interior
New carpets
New covered seats
Headliner
My .02
::End::
I'm looking to mod my 3.8. I am not going to a diff engine. There's a guy that used a custom cam, tt, etc and is making 797hp. Out of a single port 3.8.
From the calculations I'm making imma need a 62mm turbo to make in the 600hp range. Correct me if I'm wrong but I'm sitting here trying to do all the cfm, pr, and m3/s calculations and reading the graph.
ps. I don't give a f- about what this will cost. So everyone please stop trying to discourage cuz of costs. I'm mearly asking what ill need as in specifics to do it. Or if u culd post links that wuld be awesome.thanks for the help.
Old 09-04-2012, 11:12 PM   #22
xhgwx's Avatar
There is no way u can make that much power out of the single port. You would have to swap to split port. Not enough air flow...
Old 09-04-2012, 11:13 PM   #23
Ill send u the link
Old 09-04-2012, 11:15 PM   #24
xhgwx's Avatar
Unless its a huge ported single port then it's not possible... You can only forced so much air down a hole
Old 09-04-2012, 11:15 PM   #25
Here's the link. Dino sheet and all. http://www.v6power.net/vb/showthread.php?t=48406
Old 09-04-2012, 11:19 PM   #26
xhgwx's Avatar
4.3L Stroker engine...
Custom intake of course.
---------- Post added at 12:18 AM ---------- Previous post was at 12:17 AM ----------
So yes built like that it's possible I prefer split, if he had a split he'd be well into the 800s just saying.
---------- Post added at 12:19 AM ---------- Previous post was at 12:18 AM ----------
I think it's a single port engine swapped to a split port tho. He has the exact build I pretty much told u above
Old 09-04-2012, 11:24 PM   #27
Ok so what do I need? My aim is for 600hp. I don't want any more than 650hp. Going with FI ill want flat top forged pistons right, forged rods ik but what else about them do I need to know.? Also wuld 4v heads be better for what I want? What r the cam specs imma want? Etc. What wuld the numbers be for the rods and pistons?
---------- Post added at 01:24 AM ---------- Previous post was at 01:23 AM ----------
I'm not building till I have all the specs, and numbers I need. Only gunna build once. I don't wanna have a pile of good parts I keep swapping cuz I realize this or that's better.
Old 09-05-2012, 12:08 AM   #28
1slosix's Avatar
Re: turbo size??
:facepalm
Old 09-05-2012, 09:03 AM   #29
Originally Posted by 1slosix
:facepalm
I'm not changing it to a 4.3 or else id have the specs.
Old 09-05-2012, 09:52 AM   #30
xhgwx's Avatar
Go to Supersixmotorsports give them a call, tell them what you want and they will tell you everything and supply it all. ::
Old 09-05-2012, 10:52 AM   #31
austinknoll's Avatar
Le mans cars with twin turbos don't even run over 28 psi. 30psi is stupid
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 09-05-2012, 11:44 AM   #32
Re: turbo size??
Bunch of WRONG here...
Single port + turbo > split port all day every day. No he wouldn't have made 800 with split port he would have made less.
Fastest v6 mustang = single port
Most horsepower = single port
a SLEEVED 3.8 block? are you crazy nobody sleeves one of these things.
A cobra pump to make power for "30" psi? No that won't happen, dual cobra pumps with a B-A-P won't make 600hp on a v6 mustang.
Why do you need to replace the EXTERIOR to make power?! Wtf
You don't even need suspension really Tom JR ran 10s on stock suspension and made 601hp!!
Don't need a custom drive shaft.
Yes a BW s375 will get you to 600hp, so will an s366, so will a 6765, so will a 6266.
Oh and I don't know what a le mans car has to do with running high boost?? Or with anything for that.
Old 09-05-2012, 11:52 AM   #33
xhgwx's Avatar
He is rebuilding the car do I added in the extra price of the exterior and suspension because he wants it upgraded.
An how does a single port make more than a split port?
Old 09-05-2012, 11:58 AM   #34
Re: turbo size??
because when you add boost the whole game changes.
Old 09-05-2012, 12:16 PM   #35
xhgwx's Avatar
Is it because it's not having to split off and go into different longer runners compared to the big single opening?
» Members Mustangs
Sally
Fryes
Jim's '02
jwyche
Add your Mustang
07:48 PM
