internals for turbo setup?? - Mustang Evolution
Old 09-04-2012, 12:06 AM   #1
Im planning to put 20-30psi through a TT setup. Also im looking for 600-ish ft/lb@4g (is this a good rpm for a TT setup?)A buddy of mine told me that ill need a cam with a 1.5 lobe seperation. Can anyone else help me with other specs of parts ill need. I was thinking flat topped pistons wuld be best but idk. (Also ik I need forged internals. This thread is strictly for the internals ill need for my engine not for bashing. I'm new the the performance side. But that being said I'm not stupid.)
morthis32 is offline   Reply With Quote
Old 09-04-2012, 04:24 AM   #2
davidcseifert's Avatar
Region: Arkansas
Re: internals for turbo setup??
TT is pointless unless you have money to just blow..
1.5 lobe separation? LOL you measure it as LSA in degrees...
high boost low compression, 8.8 or so check out SuperSixMotorsports.com
blower/new cam soon
Old 09-04-2012, 11:50 AM   #3
From everything I've read TT is the best choice and doesn't give you lag. How wuld u be blowing money??
Also I believe he said "you want a 1 to 15 lobe seperation" I made a note my note says (1.15 lobe seperation- crankshaft) so if that's not what I want then what's best? Also what about piston tops? Do I want a flat top like I think or? Etc
Old 09-04-2012, 07:31 PM   #4
I'm checking that website right now.
11:49 PM
