Turn Signal Frustration!!! - Mustang Evolution
Old 09-05-2012, 08:44 AM   #1
Hey guys,
I am at my wits end with trying to figure out why my Turn Signals will not work on my 1994 Mustang V6. I have done a few things that were recommended and none of them have panned out yet.
  1. I replaced the Multi-Function Switch
  2. I replaced the Turn Signal Relay
None of those things have given me anything. The thing that is confusing is that my Hazard Lights work. Since those work it only makes sense that my Turn Signals would work as well. Any ideas in regards to this before I jump off of the roof...
devanslive is offline   Reply With Quote
Old 09-05-2012, 09:15 AM   #2
1slosix's Avatar
Re: Turn Signal Frustration!!!
there are two flashers...one for the turn signals and one for the hazards...one can work and not the other. spend the $6 to replace the turn signal flasher and see how that goes
Old 09-05-2012, 09:39 AM   #3
Okay, now I am confused. I replaced the Turn Signal Relay and that is the little plug like piece right behind the fuses by your left leg in the car. Is that not what you are referring to? Thanks
---------- Post added at 11:39 AM ---------- Previous post was at 11:34 AM ----------
Is the one you are referring to located somewhere else? I thought the Turn Signal Flasher/Relay was located in the car under the dash behind the fuse block.
Old 09-05-2012, 09:40 AM   #4
1slosix's Avatar
the flasher is cylinder looking plug in....usually a two prong
Old 09-05-2012, 09:42 AM   #5
That looks to be the same thing I replaced right behind the fuse block under the dash. Where is the location of the one you are referring to?
Old 09-05-2012, 09:44 AM   #6
1slosix's Avatar
in that location...never swapped one on my mustang. although most vehicles have 2 as i said before. check on google
Old 09-05-2012, 09:47 AM   #7
Okay, I will look for the other one.
Old 09-12-2012, 07:44 PM   #8
Velarde410's Avatar
The round relay fuse behind the fuse box is your hazard relay. There is another under your dash close to your steering colum. This is your relay for your turn signals. I have the same problem with my 87 gt. I replaced both flasher relays and now im going to try replacing the multi function switch. Hope it works.
Velarde410 is offline   Reply With Quote
Old 09-12-2012, 08:41 PM   #9
when you put it in the turn position,,does all the lights light up but dont blink,,if so it def sounds like the turn signal flasher like the other guys were saying,,now if none of the lights come on then it could be something else,,Now im not sure about your year but there is regular flasher relay and a electronic flasher relay,,so make sure its the right one
mymustang is offline   Reply With Quote
Old 09-12-2012, 09:14 PM   #10
Velarde410's Avatar
Yea my hazards blink but not on the dash and when I turn on my turn signals nothing on the dash or the lights. I hope a new multi function switch will work.
Old 09-12-2012, 09:22 PM   #11
That is weird because I see the relay behind the fuse box, but cannot find the other relay that everyone is referring to.
Old 09-13-2012, 12:11 PM   #12
You replaced the only two components, it would point me to an electrical problem. Fuses, loose wire/broken wire. Then the headlight switch wire harness.
Mustang Headlight Switch Repair Harness (94-04 All) 1120 - Free Shipping!
Old 09-13-2012, 12:24 PM   #13
Yeah, I am going to replace the headlight switch and harness this weekend. That has an impact on the Turn Signals as well?
Old 09-14-2012, 11:06 AM   #14
Read this, maybe reach out and compare issues.
My car is driving me crazy!!!
Old 09-14-2012, 11:08 AM   #15
There was no link
Old 09-15-2012, 12:30 PM   #16
There was no link
Yeah, it works for me. Click the blue words. My car is driving me crazy!!!
Old 09-15-2012, 12:33 PM   #17
deadsp0t's Avatar
Works for me as well!
That's unimpressive
05:15 PM
