Sad day. - Mustang Evolution
Old 09-05-2012, 11:18 AM   #1
LaseRedXD's Avatar
Sad day.
Well, I went to the alignment shop today to get an alignment, and my passenger side ball joint and tie rod end are shot.
Now, this could be my fault, I once took my baby into a field...
But the people quoted me $407.
That's labor/parts/tax. And the parts are Moog? Is that too expensive?
That's also including the alignment.
LaseRedXD is offline   Reply With Quote
Old 09-05-2012, 11:56 AM   #2
Mike SVOR's Avatar
Re: Sad day.
I'm showing ball joints price from 24 to 60 dollars each.
and tie rod ends range from 14 to 44 dollars.
You can spend the rest of the money on tools to do the job and an alignment.
You'd come out of it with brand new tools. Although you only need a good jack, a ball joint seperation fork, a sledge hammer and some large adjustable wrenches.
I've never done the sledge hammer method, but my buddy does it almost daily.
I'd probably go with the rental tool like used here:
1999 3.8 stang
1990 LX - supercharged 351w
1985 turbo 2.3 www.msvorinich.itgo.com
Mike SVOR is offline   Reply With Quote
Old 09-05-2012, 02:14 PM   #3
1slosix's Avatar
Re: Sad day.
yeah you'd be taken for a ride at that price..time to learn how to do something else luckily it's not too hard
Old 09-05-2012, 02:24 PM   #4
mustangg2000's Avatar
Region: Arkansas
There ripping you a new one on that price .. Ball joints and tie rod are not hard to change oriellys rents ball joint press in kit it press them out and press new ones in .. It's easiest way to change them!! Tie rods simple as pulling pin busting loose nut .. Breaker bar my be need to not pop your nut braking them loose or impact wrench
---------- Post added at 03:22 PM ---------- Previous post was at 03:20 PM ----------
Always best to change upper and lower while doing it or it defeats the purpose ..
---------- Post added at 03:24 PM ---------- Previous post was at 03:22 PM ----------
Upper and lower refer to ball joints
Inner and outter tie rods best to do both at same time those to then 50 bucks for an alignment
mustangg2000 is offline   Reply With Quote
Old 09-05-2012, 03:22 PM   #5
Mike SVOR's Avatar
Re: Sad day.
our moo tangs only have lower ball joints. They have upper strut tower bushings.
If you need inner tie rods, its best to replace the rack, cause its probably worn out at that point. A new rack comes with both inner tie rods.
1999 3.8 stang
Old 09-05-2012, 03:41 PM   #6
Region: Arkansas
Same principle on all .. Last ball joints and tie rodsI changed was my Z71 .. Sorry on the bit of confusion .. Still they have a press kit for install and removal .. As u can tell my truck didn't have a rack cause I forgot bout it lol
Old 09-05-2012, 10:10 PM   #7
94sccoupe's Avatar
Region: West Virgina
Holy cow. They r tryin to rape u
94sccoupe is offline   Reply With Quote
Old 09-05-2012, 10:41 PM   #8
LaseRedXD's Avatar
Re: Sad day.
I seriously love you guys. I'm definitely not going through with this place now. So, should I just replace the bad parts or go ahead and do the entire rack and maybe both ball joints? I figured why not. I just changed my shocks and struts literally yesterday, haha. I'm learning! And those tools mentioned, that's all I need?
Old 09-06-2012, 12:32 AM   #9
1slosix's Avatar
Re: Sad day.
yeah you can rent all the tools you need or buy them if you have the coin
carving corners like a boss
Old 09-06-2012, 07:39 AM   #10
Mike SVOR's Avatar
Re: Sad day.
You didn't specify if it was inner or outer tie rod that was bad.
If outer, then just get the outer tie rod end and put it on.
1999 3.8 stang
12:24 PM
