Camber bolts a good option? - Mustang Evolution
Old 09-06-2012, 08:52 PM   #1
austinknoll's Avatar
i am looking into lowering my ride and was wondering if these eibach camber bolts would work instead of CC plates? if so how low can i go?
Eibach Mustang Pro-Alignment Camber Adjustment Camber Bolts (94-04 All) 5.81280K - Free Shipping!
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 09-06-2012, 08:53 PM   #2
Re: Camber bolts a good option?
My guess would be between 1.5" and just under 2" drop.
Old 09-06-2012, 11:07 PM   #3
So you think these could work or anything under a 2" drop?
65 Mustang coupe
Old 09-06-2012, 11:30 PM   #4
1slosix's Avatar
yea most camber bolts are good for 3 degrees soo you'll be ok
carving corners like a boss
Old 09-07-2012, 03:00 AM   #5
This might be a stupid question but are they easy to use?
65 Mustang coupe
Old 09-07-2012, 10:14 PM   #6
1slosix's Avatar
yes they're easy to install...good for when you get ur alignment so they can be set right
Old 09-08-2012, 02:33 AM   #7
Well I do my own alignment so I just wanna know if they are easy to adjust
65 Mustang coupe
Old 09-08-2012, 04:37 AM   #8
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I have a set on mine. They were real easy to install, but I had a shop do a proper alignment for me since I don't have a camber gauge. Teamed with some H&R race springs, they improved the handling and turn in on my Bullitt greatly.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 09-08-2012, 06:41 PM   #9
Yah you should be fine with 90% of the springs out there. The H&R's and Sportlines might be the only progressive springs out there that really need CC plates, and even then you could probably get away with camber bolts and a good alignment.
I couldn't since my front is over 2" after removing isos but I like the option to adjust later on with the plates.
Old 09-08-2012, 10:56 PM   #10
Alright I think I will just do bolts then unles I want to go lower
Is there any disadvantages to not having insulators on the springs?
65 Mustang coupe
Old 09-09-2012, 01:15 AM   #11
1slosix's Avatar
nope...isolators are there to keep creaking down...just wrap the ends of your springs in electrical tape and you'll do the same job but without lifting the car a bit
Old 09-09-2012, 08:13 AM   #12
Old 09-10-2012, 06:34 PM   #13
So that set on AM is for side or both?
65 Mustang coupe
04:29 PM
