suspension - Mustang Evolution
Old 09-07-2012, 02:28 PM   #1
Mustang19's Avatar
suspension
I've heard many say that u can't set it up for both drag and corning. I would like to set mine up for corning but how much will that affect my 1/4 time?
Mustang19 is offline   Reply With Quote
Old 09-07-2012, 09:41 PM   #2
1slosix's Avatar
Re: suspension
a proper cornering car will not transfer weight as much and lay flat as possible in the corners..also the camber would be set up to a slight negative degree (like 2 degrees)...for a drag car for the best times you'd want a zero camber setup...and a suspension that'll transfer weight to the rear when you launch
if you want a decent cornering car i can give you a nice buildup if you want...do you want a budget build or top end stuff?
carving corners like a boss
Old 09-07-2012, 09:44 PM   #3
Re: suspension
If you go all out either way it will be hard to do the other...
If you go with a good adjustable setup you can be OK at either. I'm at a crossroad of going full drag or keeping some handling in place and debating it myself. I have an OK suspension setup for either direction but it's getting harder and harder.
Old 09-07-2012, 09:46 PM   #4
1slosix's Avatar
Re: suspension
yes the downside is you'll never be truely great at one if you build for the other
Old 09-07-2012, 09:51 PM   #5
Lorraine's driver
ab_mach1's Avatar
Do we have some info here on ME for adjusting your suspension? Or maybe explaining some of the terms?
Instagram: @ab_mach1
Old 09-07-2012, 09:51 PM   #6
Mustang19's Avatar
Yeah I would like a nice budget build for corning car bc I don't really ever plan on dropping a v8 or a turbo set up in lol and the v6 isn't much of a drag motor
Old 09-07-2012, 10:06 PM   #7
1slosix's Avatar
Re: suspension
but it's a great cornering car when done right...let me write up a good build
---------- Post added at 11:06 PM ---------- Previous post was at 11:01 PM ----------
good budget build
-cut springs (good for any build really if you wanna save a few hundred)
-sub frame connectors off of a vert (or new full lengths if you have around $75)
-rear sway bar off of a GT (94-04)
-front strut tower brace off of a 94-95 GT (needs a little modding)
-rear shock tower brace (just make ur own if you can weld or pay a shop to do it..usually run around $30 to build)
now for brakes...no need for a big brake kit unless this sees heavy autox action
-SS brake lines (i run Goodridge Gstop lines)
-Hawk Ceramic Pads
-flush and fill your brake fluid (i'd upgrade it all to 5.1 fluid *not 5.0* if you flush it fully)
Old 09-07-2012, 10:24 PM   #8
Mustang19's Avatar
Sounds good luckly I already have sub frame connectors lol what about shocks? And what exactly do u mean by making ur own rear strut tower also I've seen in other threads u recomend 1.25 off the front coil and 1 off the rear correct?
Old 09-07-2012, 10:31 PM   #9
1slosix's Avatar
Re: suspension
my cutting sizes are always for coupes...im wanting to say 1.25 and 1 will still work fine on a vert. i just noticed ur a vert so an upgrade for you would be full length sub frame connectors
Old 09-08-2012, 07:48 AM   #10
Mustang19's Avatar
How can I tell if the sub frame connetors I already have are full length?
Old 09-08-2012, 08:36 AM   #11
Fourloko530's Avatar
Im not trying steal this post but I have a problem when I have my car in park and I turn the wheels left or right I can almost see the car like pick up a lil bit
Fourloko530 is offline   Reply With Quote
Old 09-08-2012, 10:10 AM   #12
1slosix's Avatar
Re: suspension
check all the connection points on the front...
@op...a full length would look like this running 90% of the car front to back...a standard length is about half a long
Old 09-08-2012, 10:22 AM   #13
Mustang19's Avatar
I don't believe what I have are full lenght .. I tried getting a pic but it didn't turn out .. for the rear sway bar it bolts up directly and fits inbetween the differntretal and the gas tank correct
Old 09-08-2012, 10:29 AM   #14
1slosix's Avatar
Re: suspension
yes...i can't remember if verts have one or not from factory...i know they got some extra stuff over a coupe to handle the body flex that they have
Old 09-08-2012, 10:39 AM   #15
Mustang19's Avatar
Yeah I didn't even think about that .. will it affect the overall cornering of my car or will the parts just be more expensive?
Old 09-08-2012, 10:43 AM   #16
1slosix's Avatar
Re: suspension
no most parts will cost the same...just make sure if you decide to buy lowering springs that you get vert rated springs (which are a bit stiffer to handle the weight difference)...if i recall a vert is around 300-400 lbs heavier.
Old 09-08-2012, 10:57 AM   #17
Mustang19's Avatar
Will the struts off a gt still work or do I have to get the ones off a vert gt
Old 09-08-2012, 11:12 AM   #18
1slosix's Avatar
Re: suspension
i wouldn't use struts off a GT..i'd just buy those new. i dislike used struts or shocks (unless they are basically new)
Old 09-08-2012, 11:29 AM   #19
Mustang19's Avatar
I meet the strut tower braces u were talking about? Or is that considered the same thing lol .. sorry I'm new to suspension I mostly just know motors lol
Old 09-08-2012, 11:33 AM   #20
1slosix's Avatar
Re: suspension
well i was gonna say we dont run struts but shocks. but i didn't wanna confuse you moreso lol...but now that you say STB then yes a gt one will work. if you can find a 94-95 GT they came with them stock. with a little modding it'll fit your car with no issue
Old 09-08-2012, 11:47 AM   #21
Mustang19's Avatar
So my car doesn't have them? Also how much modding would need to be done?
---------- Post added at 11:47 AM ---------- Previous post was at 11:37 AM ----------
Sorry that was dumb question I was thinking about something elese but when I looked them I knew exactly what they were lol .. another question is if I cut the springs will the shocks need to be replaced?
Old 09-09-2012, 12:26 AM   #22
1slosix's Avatar
Re: suspension
i've run stock shocks on lowered stangs with no issue..however depending on your mileage i'd just upgrade...look into tokico blues
Old 09-09-2012, 06:52 PM   #23
Mustang19's Avatar
Yeah the only thing I'm nervous about is cutting them
Old 09-09-2012, 09:48 PM   #24
1slosix's Avatar
Re: suspension
not hard...and if you mess up then you can always buy those lowering springs you were gonna buy anyways
04:22 PM
