Windstar intake second thoughts - Mustang Evolution
Old 09-07-2012, 05:58 PM   #1
At first I didn't want the wind star intake bc I like my k&n intake, but now I found a way I can have both. Question now is - is Vap still selling them?
Check out this picture that gave me the k&n / windstar conversion
Blackedout is offline   Reply With Quote
Old 09-07-2012, 09:32 PM   #2
1slosix's Avatar
Re: Windstar intake second thoughts
vap is out of business
carving corners like a boss
Old 09-08-2012, 12:37 PM   #3
willrad00's Avatar
VAP isnt discontinued, hes just no longer selling the prefabbed kits. You'll have to scrap one yourself, but as far as i'm aware hes still selling some of the custom components individually to help you out.
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 09-08-2012, 06:56 PM   #4
SN95V600's Avatar
i just got back from the junk yard check my album out the pics are in there only thing is i didnt get the bolts for it it was just lying out on top of another truck
so i need all 12 bolts and the little plastics that go in the holes....any ideas if i can pick them up some where else if i cant find them
and i wanted to ask if you used a spacer on yours?
SN95V600 is offline   Reply With Quote
Old 09-09-2012, 01:20 PM   #5
willrad00's Avatar
I broke a bunch of my bolts putting mine on so i used stock ones with some thick washers to make up the difference.
Old 09-09-2012, 02:17 PM   #6
Dgerow12's Avatar
@ blackedout just as an FYI I'm sure you already know this but adding one 90 degree bend to you intake is like adding three feet of tubing
Dgerow12 is offline   Reply With Quote
Old 09-09-2012, 04:34 PM   #7
SN95V600's Avatar
well i just got back from the junkyard and was able to get all 12 bolts and the two plastics i was missing now i just wana get the block off plate for my egr and need 2 1/4 spacers
---------- Post added at 05:34 PM ---------- Previous post was at 05:32 PM ----------
and fab up the throttle cable bracket i was able to find a wrecked 3.8 there an snatched the bracket and still figure out how to extend the iac and tps
Old 09-09-2012, 07:59 PM   #8
willrad00's Avatar
Extending wires is easy, just a stripper and some connectors. The hardest part for me was the vacuum tubes, just make sure you label where everything came from.
Old 09-10-2012, 02:11 AM   #9
The vap intake is so much better than that.
Even better would be running a straight pipe into the fender with the filter inside.
ChrisTorres08 is offline   Reply With Quote
11:01 AM
