Need Repair Advice - Mustang Evolution
Old 09-08-2012, 04:27 PM   #1
bobby02V6's Avatar
Need Repair Advice
So I'm having a problem with my battery/alternator...
This morning I went to get gas, when I turned my car back on to leave, my radio turned off and then came back on in a few seconds. So after a few feet of driving through the parking lot it started to rain so I turned on my lights and watched the battery power drain considerably, then I turned on my wipers and I thought I would lose power. After turning them off I limped the car back home and got it in my driveway.
My battery is only a few weeks old so I went to an auto parts store and they tested my alternator and said it was dead (putting out 4 volts). So I buy and install a new one. While test driving my car shuts down again, can't start it up. Get it jumped and make it maybe 500 yds before it quits again. And now my driver side window won't roll up.
Any thoughts on what could cause all these issues? Thanks in advance.
2002 V6... CAI, Pypes Dual Exhaust, SCT Tuner
bobby02V6 is offline   Reply With Quote
Old 09-08-2012, 04:41 PM   #2
Kingmidas87's Avatar
On my truck my alternator went out then it drained and killed my battery. I'd have your battery checked out. Even if it's new, your car was suckin juice straight from your battery with no help from your alternator for who know how long.
Kingmidas87 is offline   Reply With Quote
Old 09-08-2012, 04:52 PM   #3
Talking Re: Need Repair Advice
I agree...take it to autozone have them test the battery or if you have a battery charger...give it a full charge
NinjaStang is offline   Reply With Quote
Old 09-08-2012, 06:04 PM   #4
bobby02V6's Avatar
Ok then thanks, I'll put it on the charger for tomorrow and see what that does. Any reason for only my driver side window to not be working? The passenger only works. It stopped working once I lost power, but even while getting jumped it won't go up.
Old 09-09-2012, 06:40 PM   #5
bobby02V6's Avatar
update: I charged the battery externally and upon reinstalling it, my window works fine as does everything else.
However, I checked the voltage across the terminals with the engine running and got around 14.5V which is normal. But after I put all of my tools away I checked it again (engine still running) and it was at about 12V and sinking at around .01 V every few seconds. when in reached about 11.75 I shut the car off.
Can anyone think of a reason an alternator would all of a sudden stop charging the battery after only a few minutes of running the car?
Old 09-09-2012, 07:04 PM   #6
Check at the back of the alternator and see if it dropps there also,,that way youll know its not a bad connection somewhere,,you could have a bad alternator,,i know its new but no unheard of..If the voltage starts to drop,,wiggle the wires around on the alternator and see if anything changes,,Ive seen alot of the autozone and advance alternators end up being bad. exspecially a rebuilt one .At work we just have the motorcraft one thats on it rebuilt,,by a alternator shop..never had any problems after that
mymustang is offline   Reply With Quote
06:08 PM
