HELP!! - Mustang Evolution
Old 09-10-2012, 01:54 AM   #1
99VSixer's Avatar
HELP!!
OK So i come to work tonight to work my overnight shift. Car runs fine. Has been running fine for a while. All of a sudden on my break I plan to go to 7-11 to grab a snack. Start the car up and immediatly feel vibrations out the *** and when I accelerate it gets worse. The 7-11 is right around the corner from where i work so when i get there i pop the hood. The engine while ideling is vibrating and when i get down near the exhaust i can hear it almost 'popping'. Due to the time of night not much I can do right now not to mention I have no tools with me. So I drive back to work I See my Check engine light come on and just flashes for like 2 minutes then stops.
Im worried to drive home once I get off work at 7am since i Live about 45 minutes from where I work. Any suggestions? No autozones nearby either to get a free code check.
I am assuming my engine is misfiring somehow someway I just don't know from where.
---------- Post added at 03:54 AM ---------- Previous post was at 03:53 AM ----------
Also, By the time I got back to work (only about 5 minutes from the 7-11 to work) I could smell something burning (im assuming gas)
99VSixer is offline   Reply With Quote
Old 09-10-2012, 01:58 AM   #2
Venomouz831's Avatar
Try to find someone that has an obd reader thts my only advice, when it flashes like tht I would reccomend not driving it.
)02 Gt, Founder of WE2G
Old 09-10-2012, 02:10 AM   #3
It's not me, it's you.
primer2tone's Avatar
You shouldn't drive it like that.
Old 09-10-2012, 03:05 AM   #4
99VSixer's Avatar
Re: HELP!!
Question: about 6 months ago Aamco replaced my Coil Pack, Spark Plugs, Wires, etc and gave my car a tune. If any of those went bad would they replace/fix it for free?
I am assuming since its likely a misfire its one of the above that has a problem.
Old 09-10-2012, 04:12 AM   #5
Re: HELP!!
You might have a stuck open injector,,becareful if it is,,you can wash the cylinder,,or hydrolock it..Hopefully its a plug or coil,,
mymustang is offline   Reply With Quote
Old 09-10-2012, 05:40 AM   #6
GTdevildriver's Avatar
Region: Arkansas
Man that's not good. Sorry.
I Could ****ing Care Less.
GTdevildriver is offline   Reply With Quote
Old 09-11-2012, 12:08 AM   #7
1slosix's Avatar
Re: HELP!!
any update op?
carving corners like a boss
Old 09-11-2012, 12:38 AM   #8
irishn8's Avatar
For now, make sure ur plug wires are all connected snugly at the plugs and distibutor, make sure all connectors to ur injectors are connected snug. If you hear rattling in ur engine STOP IMEDIATELY! If u still can't get it going, find out which cylinder is misfiring by using an obd scanner or u can pull one plug wire at a time and the one that doesn't make it run worse is the one misfiring. Try swapping wires then injector if neither help get it towed home if u haven't by this point.
Old 09-12-2012, 12:41 AM   #9
irishn8's Avatar
Update?
Old 09-21-2012, 03:21 PM   #10
99VSixer's Avatar
Originally Posted by irishn8
Update?
Ok fellas the car has been fixed. The fuel injector behind the intake manifold had gone bad and was replaced. On top of that a sparkplug went to crap. And on top of that 2 wires that were installed by aamco last time I got a bunch of work done they placed the wires directly on top of the manifold causing them to burn and crack.
All is fixed and she's running good again.
01:28 AM
