Catalyc Converter - Mustang Evolution
Old 09-12-2012, 02:36 AM   #1
PiojoA7x's Avatar
Catalyc Converter
Hey guys I'm new to the mustang word. I'm interested in a buying an 03 mustang v6 from a private owner. The problem that the car has is that it does not have any catalytic converter. How many catalytic converters does the mustang suppose to have because the owner is willing to fix that. I want to make sure he installs at least the stock ones.
PiojoA7x is offline   Reply With Quote
Old 09-12-2012, 05:39 AM   #2
1slosix's Avatar
Re: Catalyc Converter
If your in an emissions county and are forced to run them for tags then just two will do the trick. Stock they have 4 but two of those are warm up cats so pointless...if youre in a non emissions area then id leave them off
carving corners like a boss
Old 09-12-2012, 08:48 AM   #3
V6 stang's Avatar
Like he said, all about emissions; if you have them or not.
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 09-12-2012, 10:39 AM   #4
PiojoA7x's Avatar
If the guy leaves 2 on, will the car still run the same cause what about the 02 sensors. And I also think that he welded the pipes to the manifold which I think that it's not correct right?
Old 09-12-2012, 10:54 AM   #5
Horseplay's Avatar
i have an off road h pipe ( no cats) and flowmasters on my v6 . sounds awesome . who needs cats !!
Low2v
Old 09-12-2012, 10:56 AM   #6
Dgerow12's Avatar
If he welded the pipes to the manifold don't buy it unless it gets fixed. That will be a HUGE headache
Dgerow12 is offline   Reply With Quote
Old 09-12-2012, 11:08 AM   #7
PiojoA7x's Avatar
ill be sure he gets that fix. If he leaves 2 on will the check engine light turn on?
Old 09-12-2012, 11:32 AM   #8
Dgerow12's Avatar
It shouldn't as long as they are proper cats not pre cats. AM Has after market high flows that work well. They also sell MIL eliminates for 79.99 a pair that will keep the light off with a completely catless system. As long as they don't do visual inspections and you like loud throaty exhaust then I would do cats off but that's just what I prefer
Old 09-12-2012, 11:44 AM   #9
PiojoA7x's Avatar
With 2 cats. Will it have the 4 banks for the 02 sensors?
Old 09-12-2012, 04:58 PM   #10
1slosix's Avatar
you have two o2 sensors (upstreams) and two o2 monitors (downstreams) the upstreams work with the cars computer to help set the air/fuel mix...the downstreams only job are to tell the computer about the catalyst effenciency.
the upstreams are there now or else the car couldn't move in most cases lol (i had one go out while cruising...not fun)
the downstreams may of been cut out by the previous owner. if so when the cats are welded in so will o2 bungs for the downstream sensors. not hard to do for a shop.
also if you want to kill the code for o2 sensors try the non fouler trick. buy a couple spark plug non foulers and bore a 1/2" hole through them (make sure the thread is the same size as your o2's). now put the non foulers in the o2 bungs...then put the o2 monitors into the non foulers other end. pretty much fools the computer everytime about the cats being there
Old 09-14-2012, 10:32 AM   #11
PiojoA7x's Avatar
I only see one sensor. It an upstream one. Located on the driver side. And im not if it works. What will happen if I don't install the 3 that are missing? Will it give me low performance? Low gas mileage?
Old 09-15-2012, 12:31 AM   #12
1slosix's Avatar
Can u take pics? Because something is off big time here...you have two manifolds ergo you need two upstreams
Old 09-15-2012, 12:44 AM   #13
PiojoA7x's Avatar
Never mind about what I said before. The owner installed all the 02 sensors. With 2 catalytic converters. He left the manifolds. I'll fix that later on. That shouldn't be a problem right ?
Old 09-15-2012, 09:21 AM   #14
1slosix's Avatar
Im confused
Old 09-15-2012, 06:13 PM   #15
PiojoA7x's Avatar
The owner is just going to install 2 catalytic converters, and the 02 sensors. But he is going to leave the same manifolds.
Old 09-15-2012, 08:51 PM   #16
1slosix's Avatar
that makes sense
Old 01-05-2013, 12:04 AM   #17
PiojoA7x's Avatar
Is ok that the pipes are welded to the manifolds instead of bolted on?
Old 01-05-2013, 12:46 AM   #18
davidcseifert's Avatar
Region: Arkansas
Sure, that's how my long tubes were for a long time
blower/new cam soon
10:47 PM
